Maybe my next casingP400 Tempered Glass Review.
There is an 'S' version, as in, P400S Tempered Glass - http://www.phanteks.com/Eclipse-P400S-TemperedGlass.html
Will you be bringing this in?![]()
not at the moment
Please consider bringing this in
Or can I indent?![]()
to each his own, looks are always subjective![]()
New Phanteks Enthoo Evolv mATX Tempered Glass Review.
The guys from Ocaholic took a closer look at the new Evolv MATX and awarded the case with a "Platinum" and "Editor's Choice" award! Check out this excellent review and nice pictures in the link below.
https://www.ocaholic.ch/modules/smartsection/item.php?itemid=4080
Just modded the top panel to allow more air flow since the air flow for this case sucks.
Gonna wait for the perforated metal sheet to come then will cover the holes underneath the panel securing using the screw holes
Draw, Cut, Clean, Screw, Fix. Haha.
Just took the plastic clip ons out, draw the design and dimensions and get them water jet cut. Now waiting for my perforated metal sheet to come. Will spray paint the sheet to cover up the holes by securing it with the screws via the screw holes. Simple mod to help the with the air flow. Will get the front panel cut too.
How much to get professionals to cut?
