[CASE] Phanteks Enthoo EVOLV ATX
evq
ah i see..if mine is TG version cannot switch open..?
Very troublesome, have to remove the 4 screws, and handle the glass carefully each time. No point, just get an external drive.
@Corbell
Suspended
New Arrival!!
1) Phanteks Eclispe P400 Tempered Glass
SRP $139
Available in Black, White, Grey and Black/Red
2) Phanteks Enthoo Pro M Tempered Glass
SRP $159
LiLAsN
can the top of ENTHOO EVOLV ATX GLASS hold 3 x 140mm fan ?
Can refer under the cooling category
Or you can refer to the full manual on page 16 directly
http://www.phanteks.com/assets/manuals/PH-ES515ETG_Western.pdf
gary92
For those guys with the TG version, can someone help me out? I cant seem to find the RGB extenders anywhere in my case. Its the cable which im supposed to plug in some extra phanteks lighting strips to be able to control it with the case RGB switch. where does that cable lead to?
Kusanagi
it's a cable with 2 pins, one of which that's says "USE ONLY WITH PHANTEKS RGB STRIP"
gary92
The problem is that i dont have that cable. Any idea where it traces or attaches to? then i can back trace
technoglitz87
anyone knows if the rgb extenders will actually support normal rgb led strips with the same 12V G R B?
Phanteks leds are way too ex
Kusanagi
no, the header of the extenders will only work with phanteks LED strips if im not wrong
gotta use your on board rgb header
