NeonX
- Jan 1, 2000
Where did you route your front fans and aio cables?Mine all using latest tech, all wireless powered! muahahahha
Sent from Samsung SM-G955F using GAGT
looks very nice!
but the small holes, looks like more than 50% restrictive...
Vent holes are cut meant to allow more air flow. Grilles are added to prevent stuffs to be dropped into the rig itself. I believe all casing which has ventilation holes they are covered with grilles as well. Anyway mine is 3mm holes. It should do fine.![]()
real nice job, i wudn't even kno where to startVent holes are cut meant to allow more air flow. Grilles are added to prevent stuffs to be dropped into the rig itself. I believe all casing which has ventilation holes they are covered with grilles as well. Anyway mine is 3mm holes. It should do fine.![]()
How is the new temp like already? Does it improve alot after cutting the holes out?
it the mATX tempered glass version of this case available yet?
you meant the following?
Phanteks Enthoo Evolv mATX Satin Black
He meant the new model with a swingable Tempered Glass that is even better than the current ATX model with its screwed on glass.
yep this is the one. awesome....
looking at end June arrival![]()
price tag? Maybe I can wait till that time.
I can't give u a definite answer now as some of my fans and one of my GPU are removed due to getting ready for the wc setup. But last week for me when I was still using dual Strix 1080ti, the temps was decreased by 2 - 3 degrees. Do note this is the TOP card which has little fresh cool air and its running air cool.
But I could confirm, by using the tissue paper I am able to see the air is moving in and out of the case with not much restriction.
Comparing to the default case panel I believe my mod is definitely an improvement to the air flow. But if u want technical numbers I will get back to u when I done up my wc setup.
it should be about $219
This I likedPray hard hard for
1) You list it on Qoo10
2) Qoo10 has nice coupons
3)![]()
Nice! Now that I see your setup I super tempted to try powder coat the Front and Top panel with Silver colour!
