Ceiling Fan Recommendation
batniss
Does it work with those smart IR controller from Tuya smart and connect to Google home?
It is on RF so it wouldn't work with an IR controller instead what you need is a IR+RF controller and have to support GHome.
rsandgy
Hi, there's a beam cutting across my masterbed room, so the max fan size i can purchase is 36". So far I came across a few brands e.g. Alpha, Fanco & Efenz (34").
Would you recommend any of the above of would you know of any other brands that offer this size please?
dude1991
Hi all,
i am considering to install ceiling fan/w light in my bedrooms however, i am worried the lighting will not be sufficient for the room. any advice on this?
wacko
Hi all,
do the light turn on when you flip the switch for the fan? if it doesn't, I think it's rather impractical.
jaychou321
Bought 3 ceiling fans and self-installed them, but one of them was a lemon. Is it normal for distributor to claim warranty is voided for fans not installed by them?
cstanhwz
Fanco?
Yes, encountered before. They put the blame on me. Despite the technician came and say that something was not secured inside during their production.
jaychou321
Fanco?
Opple wood leaf fans, $136 from 131express.asia on Lazada. They have removed the product from their store. Now they ask me to buy replacement remote and receiver for $49.
speedbolt
Recently my fanco B-star ceiling fan light spoilt. the wire is blue and white. anyone knows how do i connect blue and brown frm the new led i bought?
Dan10
Hi, can anyone recommend any ceiling fan that works for 2.6 m HDB ceiling height? How to do it when i understand there needs to be a distance of 2.4 m between ceiling fan and floor?
GBC
Haiku fan with a short mount.
wahlaueh888
Just installed PO Fan Gust
so far so good
46" version for my room
The wind better than my old Crestar 5 blades fan
Hi, do you know if the p.one fans show up directly in google home or needs to connect an account to Google home then login then can see the p.one fans?
