Deceased
- Sep 26, 2021
U can use the fan light to replace the ceiling light.Huh… then one of the ceiling lights will always not be working…
You can daisy chain it.. or use a fanlight as mentioned..Huh… then one of the ceiling lights will always not be working…
thanks bro.it does work with Google Home. However the only option you have directly from GH is, On/Off.
PO Eco fan remembers last state so if the last state was Fan speed 6, light warm - when GH turns it on, it will be at that state.
as long is local, PO Eco will honor the warranty.thanks bro.
can share buy direct from Point One or other resellers ? noticed theres other resellers or buy from lazada / qoo10 ?
Are Efenz fans worth the higher price point?
Im looking for fans with light. The shop told me this is easier to clean, some designs hard to clean at the area between the led and the motor.I think u r buying more for the design...
Functionality/wind feels normal like a normal fan shud be. But only my experience at the shop lol. No comments on long lasting all that
Haha but its like $400-500 more than other fans.
Which brand did you go for in the end?
think this Panasonic Wifan dont support Google Asst / Alexa right ?https://www.panasonic.com/my/consumer/air-solutions/ceiling-fan/f-m15gcvbksh.html
Just bought this at tampoi lighting centre for 925 myr.
No idea. Have not set up the fan yet.think this Panasonic Wifan dont support Google Asst / Alexa right ?
they accept credit card?https://www.panasonic.com/my/consumer/air-solutions/ceiling-fan/f-m15gcvbksh.html
Yes but I think they might charge extra for cc. I always pay by myr cash for best rates.they accept credit card?
I'm looking for Alaska ceiling fan, is it good and is the Samsung LED light bright enough for study room. ThanksI went for efenz for living room (no lights) because i liked the design
But for other rooms, i went for Alaska Ferm Slim III models cos they also looked good + cheaper. Something special about this range supposedly is the lights are dimmable and you can switch between the 3 light colors without on-off-on-off-on-off.
I think is mostly see which design u like.. reliability should be ok ba...
If want both, then Haiku i guess (but this one the wind speed abit poor with the heavier wood blade ones)
Update : yes - the fan only support proprietary Panasonic app on ios/android.think this Panasonic Wifan dont support Google Asst / Alexa right ?
Hi All,
Anyone got experience or insight on Bladeless fans?
Might be considering the Flaire ERA Bladeless fan for my new bto.
https://www.sembawanglightinghouse.com/amp/flaire-era-29-bladeless-ceiling-fan/
Thanks in advance!
Cant recall which retail shop i demo it but the air is rather weak one
a little noisy, and even the person said cleaning not easy
Overall wouldnt consider it unless you really so tight on space.
