Ceiling Fan Recommendation
wongminmin
The more durable brand is fanco and KDK?
Looking for ceiling fans with lights.
u can ask shopee aveavenue , they are very professional and explain every thing in details.
1 of their replies.
depends which model you are referring. In terms of Branding, Crestar position slightly more premium than Fanco. In terms of after sales service, Crestar is much faster to arrange. By best selling products from the brand, Crestar is valueair and fanco is Bstar. Value for DC type of fan will be bstar at $189 which is the cheapest in the market with remote and led light. Wind generated is bstar fan much stronger. Noise generated is valueair is much more silent compare to bstar. Led light brightness is valueair brighter at 20w and bstar is 18w. Hope the above clarifies your concern. Thank you 😊
baileysGirl
Went and experienced Bestar Vino at Serangoon Central area... finally a place without aircon so I can know if it's due to the fan itself. Pricing is okay, $268 - $288.
Anybody using Bestar Vino? seems like its quite new
ho_kuku
Hi @baileysGirl , i got one vino for my place and I can say its quite a decent fan. It has got good wind - but if there is on negative - I'll say its abit loud. Just abit only. Other than that - its a decent performer. I got it at Balestier Road - LE Lightings. The staff Mr Willy is great - I got Bestar Vino, Razor and Efenz. All those can be controlled by Smart RF controller - good for smart home :)
t258jgn
Just installed PO Fan Gust
so far so good
46" version for my room
The wind better than my old Crestar 5 blades fan
Have used KDK, Fanco, Crestar
KDK uses IR remote. The remote controller spoil easily but can get from Laz or Shopee easily for $30~$50
Those fans use RF controllers, average 2~3 yrs will spoil. Need to get the service center to send technician to change. Cost of RF remote + Receiver + technician = over $100
batniss
so far so good
got mine too 54". so far so good.
t258jgn
The PO Fan WiFi version comes with the ugly White Remote Controller
Sian
shadow84
so far so good
Which Gust blade design number you get?
amazingone
Any other ceiling fan brands that uses IR remote other than KDK? So far I see many uses RF remote..
coyote
one thing i really like about efenz fan is, the remote control works even if it is behind a wall... u dun have to point at it.
Does it work with those smart IR controller from Tuya smart and connect to Google home?
