Ceiling Fan Recommendation
Donkey2019
For a normal hdb 4 rm
Living hall - recommend at least 56inch or 60inch Dc ceiling fan
Bedrooms (if rooms have built in wardrobes with casement doors types consider smaller size if it‘s sliding doors type will be bigger ones)
Two common bedrooms - 46" or 48" A.C ceiling fans with lighting kit.
Master bedroomn - 48“, 50” or 52 AC Ceiling fans with lighting kit.
Can forget about the brand amasco as they are well known un-contactable or so called play cat and mouse game for their repairs service.
Haiku fans if vitamin $$$ alot, might as well consider Spin
Fanco quality slightly above the average with reasonable price, but no choice for big size fans
Acorn a.c fans for big fans might need replacement of capacitor after some years.
Elmark is old timer or established brand, for me would be trying out their 60” DC Ceiling fan for living rm soon, so can‘t say much yet.
jasonllh
Fanco Acon 42” Wood Ceiling Fan
anyone knows what radio frequency the remote uses for this model? it is not infra-red
Kirakun83
Looks like seldom got ppl buying n install wall fan. Is it because of home theme or ceiling fan is better than wall fan?
fyourlife
For those ceiling fans with lights attached, are the lights dim ?
I'm thinking to use just ceiling fan light for the bedroom if possible.
Kennwee
I am using Crestar ceiling fans with LED light. The light is surprisingly bright but the fans have annoying clicking sound whenever they are powered on. The technicians said that it's a common problem for ceiling fan with LED light.
It is better to install separate light beside ceiling fan.
viix
Looking at installing ceiling fan for my parent's place.
It has a recessed area with 57" width on the flat surface with a cornice trim around it.
One one side there is a pelmet depth of 48cm for curtain
I hear some shops say can install only 32-36" cause need 2 feet clearance from the pelmet obstacles. Some shops say can go for 56" as there is space front and back for airflow?
Getting confused by what they say.
Any expert can advise how big of a fan I can get?
Any one installed and has a same situation as mine here?
Here's a profile view of what I meant.
imageupload
weeza77
I'm no expert but you can go for 52" fan. The blade will be roughly about 10" from the ceiling. Just don't go for those "hugger" type.
caniggia
Currently i have a 42" ceiling fan but doesnt get much wind from where i was sitting on my couch in the living room. Only my lower body feel the wind. Living in 4 room bto flat.
I have a 60" by 60" cut out of the false ceiling. The fan is installed in between the cut out.
Is it due to the size of the fan?
itsmee
Wats the difference between AC and DC. N what is recoomended for which room/living.
zulthezookeeper
Looks like the cut out is hindering the air intake.
zulthezookeeper
Just means energy saving. But I feel that when you want to fix it yourself by parts replacement, it will be tougher since it's mostly electronics.
itsmee
My hse using ac for living room i feel ac more powerful than dc. Is that right?
zulthezookeeper
In machine manufacturing industries, AC powered devices can generally output more power and is less costly versus the DC counterparts. DC powered devices claim to be energy efficient because of the variable speed drivers or something similar that adjusts the power consumption based on the requirement.
tl:dr
More hot = more fan speed = more current/energy
AC devices more powerful at times
Hope it helps.
viix
That leaves around 9 inches at the side for the air to circulate round the back to be blown down. Maybe lower the fan below the cutout if your ceiling is high enough or get a smaller fan
viix
Ac can push more wind but the motor can get hotter. Dc is more efficient but to provide that efficiency, the motor is smaller and therefore rpm and torque is lesser.
cscs3
In general, AC motor also more lasting then DC motor (which required more electronics circuit too).
Yes it use less power, but is also much more expensive. You probably cannot brake even for price you pay vs electrical saving in 10 years.
