Ceiling leaks
deathan9el
Honorary Mentor
same issue back then on our house
called up its branch office about the matter
officer came down to have it check *
then went up to the above unit as well
thankfully, nb'r above was cooperative
shared the cost but can't rem how much :s22:
nor me could recall now what was the exact cause
as that was more than 10 yrs ago, me thinks?
now like no such issue
* pls be sure u will be at home or other fam members when an appt is made
Darkshadows
last time my 5room hdb flat the kitchen ceiling got water dripping (i believe whenever upstair neighbour wash their kitchen the water will sip thru the crack and drip in my kitchen)
i called hdb and the sent their SUPERVISOR and after he check upstair neighbour kitchen and came back to me he told me to ownself buy cement and do myself.
i was like if i know how to do i dont have to call hdb!
well i sold my house and let the new owner solve the problem.
Wow damn fugged up leh that cmi hdb supervisor.
popdod
It will take some time to get it rectify.
somehow HDB lack manpower to solve these kind of old HDB issues. :(
semiret
Since you mentioned that I go searched my file. My downstairs complaints leaking from my kitchen toilet ceiling. That's was during 2013, HDB charged me 221.35 for that.
Muthucurry5678
What has hack the floor to do with ceiling leaking?
It could be due to upper unit Pipe leak hence resulting to your ceiling leak or other factor
Like i mention, approach TC & HDB pertaining to the ceiling leak, they will come and retify and speak to the upper neighbour
As for payment, be it 50/50, they will inform you after retify
Have to hack the floor to redo waterproofing. Top level water leaks to below level slab soffit.
Very very rarely will be pipe leaking that cause leakage.
semiret
what they did on your side then? :o
They hacked the floor tiles and lower part of wall tiles, replaced a new toilet bowl , relayed waterproofing chemicals. I actually paid another 2K for workers to redo wall tiles to half high of toilet. As the tiles provided by them don't matched with my existing wall tiles.
106gunner
My parent flat at amk leak is due to the kitchen pipe
Refer the matter to TC and the property officer approach the upper unit neighbour
Next change the pipe
Can't recall is 50/50 or who foot the bill more
Hack floor redo waterproofing not expensive if contractor recommend by HDB/TC
If ownself go source, sure chop you gao gao
TimsTom
My shower water leaked downstairs so I applied it onto my toilet floor.
I will pay $300 to solve this problem tho, it's so cheap.
But for my time, HDB asked me to find a private contactor. The quotation for apply this nano thing is already 2k+
Oh its ur own masionette unit? For mine is hdb flat and upstairs is neighbor. If same situation like u, i also think do simple nano to the upstairs floor try if it works.
Thats what HDB suggests. Actually could try other methods to fill up cracks/small holes. Makes me wonder if HDB comtractors wanna earn money..
TimsTom
That only costs u $200+? When was it done?
fire
Your case is technically not a leak bc it's a blocked water pipe?
It's blocked pipe which had lead to other issues. There were hacking through the flooring and repair work done.
deathan9el
Honorary Mentor
got fix 24k gold tap as well? :crazy:
deathan9el
Honorary Mentor
Year 2013.
were u flustered when the officer came over to check? :o
like the fault lies beyond your knowledge & had caused inconvenience to the unit below
tsk
but really thinking about it, this issue will occur to every household after say, a long period of time of occupancy
can be quite bothersome imo
semiret
tsk
The most annoying part was after all that fixed the whole house was covered by dusts. But actually they only hacked the 1 toilet. It took few days to slowly clearing those dusts. Haha
amransan
In my heart I wasted my time Taking leave and waited for the supervisor he came like 4pm like that I think after he done with me he go straight home lol
Muthucurry5678
Hacking and redo waterproofing is the best way to settle water leaking issue. PU grout is not recommended because sealing 1 crack may cause water to flow to another crack
Honeydewz
Juz visited my neighbour
It appear that the drainage is sealed aka no in use so I guess it's pipe issue?
TimsTom
But since its harder to convince neighbor to stop using bathroom for days and the higher cost, maybe can try another alternative first to see if it could have solved the problem?
