By 3+ years, if spoil, its time to change liao...$199 for 3 years= $66 per year = $5.55 per mth... quite cheap la.
A lot says it degrades the sound as compared to using directly from the soundcard ports... FYI, they were using headphones...
The Z uses normal capacitors whereas the Zx, ZxR uses better... but if compare Z with x-fi titanum hd, whats your verdict?
Z, Zx & ZxR uses the same nichion gold caps
I have the Z
For pure music listening, which card is recommended? X-Fi Titanium HD or SB ZX since both price is the same, which is S$199..
Thanks for your recommendation. But I'm attracted by the ZX series feature which is the speaker n headphone swapping, plus the ACM.. On dilemma now..
Which card is good for gaming/movie/music ? Thought of buying one too
Try Zxr or THD
