Custom Watercooling [Recomendation]
Masa27
@Kurui @joshuaho
Want to ask about the blocks for CPU GPU and maybe mandrel kit. No experience in bending
hg_wng
For those that have ordered from the stores before, what shipping service did you use?
joshuaho
Huh cpu I actually just get supremacy Evo Lor, GPU is standard for each model one Ma, difference is the finishing
Mandrel can get from barrow. I'm using the one with adjustable angle on one side
@Kurui @joshuaho
Masa27
The supremacy you referring to is bykski or EK?
Barrows fittings + bykski block can?
XcoldstarX
Bykski EVGA GTX1080 FTW waterblock vs. EK Waterblocks EK-FC1080 GTX FTW
Part. 1
Similar boxes
EK has a lid over the block, while the Bykski block seats freely in the box
side by side comparison of the 2 waterblocks
Close up of Bykski block
Close up of EK block
XcoldstarX
Part 2
Under side of both blocks; notice the machining marks on the EK block
Underside of Bykski block; smaller area for die coverage
Underside of EK block; block is more clean in terms of chemical residues, but the machining marks are very ugly
Side profile of both blocks; Bykski block has a noticeably thicker plexi top
XcoldstarX
Part 3
Bykski block; unnoticeable machine marks on capacitors' clearance hole
EK block; heavy machine marks on capacitors' clearance hole
Bykski block; close up of water channel fins over gpu area
EK block; close up of water channel fins over gpu area
Bykski block; close up of block near port area; notice the finer machining marks
EK block; rougher machining marks compared to the Bykski block
Part 4 will feature photos of block installed on the card. Unfortunately, I won't have the EK backplate for the EK block, so for the EK block, the card will not have a backplate installed.
Donten
you just sold me on the bykski. half the price for better finishing. the only thing i like more about the ek is the acetal ports and ek metal plaque. but damn, a china company putting in more effort than a european company, im really impressed.
edit: just went to check msi ek blocks. the milling marks are also there so its quite in line across their range im guessing.
sglords
Halfway through ~
Barrow fitting gt some chemical residue left inside...
idjekyll
Quick question. Does bykski have those AIO options? Like the discontinued EK XLC with QDC? Thinking about going that direction with the EK MLC to cool by cpu and gpu but I'm sure that's gonna cost and arm and a leg.
XcoldstarX
They don't have pre-built kits.
