Custom Watercooling [Recomendation]
kurui_
XcoldstarX
Mounted the Bykski block this morning and found the following :
1. They didn't provide appropriate thermal pads for the voltage regulators, luckily I had 0.5mm and 1mm thermal pads from Thermal Grizzly on standby.
2. The installation manual sucks
3. The screws provided for backplate mounting were too long, I went to dig for M2 screws from my MINI4WD collection to mount the backplate.
4. Thermal Grizzly's conducnaut liquid thermal compound is a PITA to apply.
End results: despite the above I am still very happy with the Bykski block. Will post photos later.
hg_wng
hg_wng
They didn't provide thermal pads at all or wrong size? Also I'm assuming they're not so good as to give thermal grizzly with their blocks right?
kurui_
Is it ok to use back the thermal pads given by evga that are currently in used? Or need to buy new ones to install?
XcoldstarX
They provided 1.5mm thermal pads for the vrams, but no thermal pads for the voltage regulators. But I already ordered Thermal Grizzly pads as they seem better. For EVGA 1070 and 1080 FTW, you need 0.5mm for the power chokes amd 1.0mm for the voltage regulators. And if you intend to use back the stock backplate, you will need to get some M2*10mm screws.
royfrosty
Sometimes i think i rather buy Bitspower waterblock lol.
Cheaper than naming brands, and finishing also good, and no need to headache with thermal pads and screw differences lol. Top notch installation manual with easy to see and read. And shipping from TW is still cheap.
XcoldstarX
Bitspower block almost EK price liao.
royfrosty
Nope. Order direct. Not unless you talking about US PCS.
Edit: It is slightly more ex than Bykski around $20-40 more depending on the model you want, but cheaper than EK.
Thats why i bought the r9 fury X from them instead of supporting EK back then. I paid premium for it back then, as im the first one whom gotten hold of it. $189sgd with back plate. Till lately i found out that their fury x water block and back plate went down to $160.
But really, quality wise, it is great from Bp TW. Cant go wrong with them either.
But overall to each of their own. If saving a couple more bucks but have to find screws and thermal pads etc on your own, then by all means go ahead.
But im more towards, easier installation guide, and everything well provided.
XcoldstarX
Too bad they don't make blocks for EVGA FTW cards.
From photos their blocks looks impressive. Much better than EK. If they had blocks for EVGA FTW cards I would have probably gotten a BP instead of Bykski. Unfortunately, EVGA FTW blocks are offered by EK, Heatkiller and Bykski.
hg_wng
To me it's about value for money, if bykski can match or come close to EK quality then I'm up for it. But if the price difference is not that much from a reputable brand like BP, I'd probably go with BP since you know exactly what you need will be included for a little more.
How to see the prices on the BP website?
royfrosty
You can request bro.
All their things can be customise and build to order lol.
Thats how i asked Lily to help me do blocks for my Fury X back then lol. It sounds shameless when there is no block on their inventory lol. But just email in and asked. Waited about a month for it and gotten it before they announce/launch.
royfrosty
There is no pricing, just email in. Or if some of you wanna chat can chat or call her in skype.
Then they will quote you. Best of all no need scared exceed *erhemmm*. Just ship over.
The first time i bought from them she gave free express shipping woot.
CurryRice999
Hi bros, currently my computer wont post. And i want to ask is if i actually fry my mobo by filling up the loop without removing the 8 pin header? I use a jumper for 24 pin.
shadow84
Remove the molex power cable for pump, plug in 8 pin cpu and 24 pin mobo cables. If its X99 mobo, mount a gpu for display. Put in ur rams and OS drive to test. Can it still boot?
CurryRice999
Thanks for the suggestion. Will try it when i dismount tomorrow morning. But the last i tried to boot it with ram 24 pin 8 pin and onboard graphic doesnt work. I remove pump ssd etc. But i will try again. No harm trying a few more times before i dismantle and ask shop for help.
