Custom Watercooling [Recomendation]
kurui_
Ps to ask again,
see a few members using 1x slim 360mm radiator to cook radiator and 1 CPU.
It it enough if want to overclock both CPU and gpu. Or is it better to add another 120mm radiator?
TIA! :D
royfrosty
Ps to ask again,
TIA! :D
Like my build >>>>>
Single 360mm slim radiator.
It is just minimal you need to go. Depends on which cpu you choose. X99 usually can be very hot depending on how high you wanna hit.
But so far im hovering around 60plus on 4.5ghz 1.256v overclocked. Gpu can hit anywhere around 63degC.
If i pull down to 4.2ghz at 1.125v my cpu never hit 52degC.
Gpu turn out to be hotter than cpu for that case lol.
But if you are coming in from skylake/kabylake. It is less worrying on the cpu side. Gpu should be hotter.
sglords
more the merrier :s22:
i like to squeeze every possibility out of the case
kurui_
Don't really want to open up my top covers of my Define S if possible haha, don't have dust filter at top and My house very dusty.
So considering to do 120mm at back (exhausting) and 360mm at front (intake) if need be. (Hope don't fry my mobo)
Like my build >>>>>
Yup yup, I'm cooling a last gen skylake i7-6700k haha
Hmmm... are fans set at lower rpm? Or need to ramp up to higher rpm to help with cooking?
royfrosty
Fan settings are purely depending on fpi of your radiators.
The higher fpi anywhere between (13 to 18) you will need a high static pressure fans to push that much air through it. The rpm indeed needed to push more air through.
For my case im using GT fans for my Hardware Labs nemesis gts 360. High fpi and restrictive radiator. Idle at around 1500rpm. While on gaming load, fan will hit 1800rpm which is optimal for my radiator, and for other cpu stressful applications, my fans will peaked out 2200rpm.
kurui_
Looking at slim radiator for front intake, a magicool g2 360mm iirc is 16fpi too but performance pales in comparison to hwlabs gts360 worried that it'll not be enough.
Hwlabs a little hard to get over here, so far only see ppc have. I've gotten 3x Gt 1850 pwm fans already too.
Hmmm... will 1800rpm be a little noisy?
royfrosty
1800rpm on GT? Nope. Not unless you are in a total silent room or at night.
Remember, radiator is something you must look into when buying in a watercooling loop. Skimp on quality your temps also will take a hit.
But remember one thing, it is not the thickness of the radiator that matters, more on surface area of the radiator*.
Since you are using the define S. Try to use the top rad and the front rad will do. Go for dual 360mm if you can. Top slim rad, but front can go slightly thicker. This would be the best setup in both temps and higher cooling capacity.
kurui_
But remember one thing, it is not the thickness of the radiator that matters, more on surface area of the case.
Was looking at a 2nd hand 60mm thick ekwb xe360 but it seems too thick for the front after adding fans.
Hmmm.. the magicool radiators of not so good? Hwlab gts360 seems to be perform better than most thicker radiators at lower speed.
hmm.. 2 x gts360 recommended?
*edit*
Link to my reference:
http://www.xtremerigs.net/2015/02/11/radiator-round-2015/5/
royfrosty
*edit*
Magicool is cheap lah, but performance and quality not to my liking loh. Depending on you.
Surprise right? The GTS 360 such a slim rad and performs very well despite comparing to thicker rads.
But note that there is a limit to this radiator. This radiator can hold around 3xx watts worth of thermal output at most. So if you want a higher performance radiator, you might wanna add more radiators.
2 GTS 360 may not be that great in terms of flow rate. 1 GTS 360 is pretty restrictive. So might wanna go easy with a slightly thicker rad for the top instead. Probably the HW Labs GTX 360. That rad is around 54mm thick. But check from the top to the VRM mobo heatsink. How much space clearance do you have.
kurui_
Just measured again, top if fit thick radiator will block the ram slots. The heat sinks won't be affected as define s top mounting is skewed away from the motherboard.
Front can fit in a 60mm radiator if mount the res on the fan/radiator.
Think I'll try one radiator first, if not satisfied than add another one. Better to get gtx360 or gts360? Or xe360 also good?
royfrosty
For the front if you want a thick radiator, go for gtx360.
The top if bo pian then go for gts360 instead.
But make sure the clearance is enough for two 360mm radiator. Especially the front mount and the top mount when mounted, it should not be touching each other. Also note that you must take into consideration on the fan 25mm thickness.
So if you take the gts360 it will be a total of 55mm thick.
gtx360 with fans would be 79mm thick.
kurui_
Think I'll get a hardward labs gts360 to try first, thanks for the advice roy!
Anyone going to order items from PPC? Can share shipping haha
shadow84
anyone knows where to get petg tubing locally?
Try fb msg xtreme solutions. Otherwise, try barrow taobao? Scorpio at sls lvl6 sell quite ex. Or if u stay near woodlands, can look for adeep91, he is reachable in vrz.
blackestvoid
thanks
taobao shipping is killer, long waiting time also
any local retails hardware shops?
does it come with > 500mm lengths? 500mm seems to be the standard
hg_wng
Saw someone who brings in barrow products on carousell, can try there but of course price is higher than taobao.
