Diesel Car Kakis
edwinttt1978
My 216d creaks a lot too. Quite annoying and totally not what I expected of BMW's build quality.
So, the creaking applies to both 1 and 2 series diesel.
The 3 series creaks a little too; the 5 series does not.
BMW does not want its quality of silence to be replicated in all its series.
greddy88
add in the ves, all the saving is out of the window unless you drive more then 220k in 10 years.
Simplify it. Treat it as part of the upfront car price just like the ARF and what nots when we buy new car.
Otherwise, get pre owned. First owner absorbed already
nfshp253
:( Maybe the new 5-series does too. Give it some time. Mine took about a year before those creaks started appearing. Now it's more noticeable than on my 3-year old Volvo S80.
greddy88
Don't understand.. Creaking sound appearing in diesel cars?
edwinttt1978
So far, no sound coming from a less than 2-year-old 5 Series.
The sounds from 1 series became audible right from start.
The solution is simple: put adhesives in the doors, but this may require dismantling the doors. This tricky solution may also end up giving more problems.
azarel
You mean applying friction tape at the door? Yah seems to fix the creaking sound issue and there's no need to remove door etc to apply.
Sent from Sony G8142 using GAGT
taylor0875
is SPC diesel bad for a car.
Hi i am new to HWZ and just bought a Infiniti Q30 Diesel.
As i normally put SPC petrol, would like to continue using SPC Diesel as it has the best CC discount for me.
Have been hearing news that SPC diesel is really bad and some Engines have been affected because of this. Would like to know if this is true..
Thanks!
azarel
nope. SPC diesel is the same as Cnergy diesel and i have been pumping Cnergy diesel for my 116d for the past 27k km and never encounter any issues with it.
IcYFl4mEz
Thanks!
how much Tax you kanna? VES
edwinttt1978
Thanks!
Of course, it is not true, at least for diesel sold in Singapore.
But if the news, known as “superstitions”, affects you, then SHELL diesel may be the better option.
HMAN
I am new to Diesel car, going to collect my car soon,as occasionally i will need to drive to Malaysia with 500KM distance on a single trip , very likely will need to top up on the return route.
So far any bad experience on Malaysia Euro 5 Diesel ? which brand gives best stability in term of maintaining car power.
Lower car power is an indicator of car ECU takes protection to lower car power due to bad fuel . This is very true for Petrol car .
Swing from relatively high consumption 2.5L Tubro charged Petrol car, definitely fuel cost is not a big concern but fuel quality for the car performance and car health is important to me.
IcYFl4mEz
gratz! which model you bought?
anyway for diesel, is not like petrol octane.
even if you pump euro2, the most make ur exhaust dirtier, as long as not always.
greddy88
Just make sure u don't take the black color pump. That one is Euro 2. There's no way black can be Euro 5.
Shingoz
Yes there is a 5%/8% rebates using Maybank Family card for pumping Smart Energy Diesel. Still checking on Citibank cash back card :)
How did that work? I thought smart uses their own card. We merely uses our cc to top up that card?
HMAN
Any diesel comes with additive like shell vpower which gives you more responsive drive?
Sent from Google PIXEL C using GAGT
