Diesel Car Kakis
HMAN
gratz! which model you bought?
anyway for diesel, is not like petrol octane.
even if you pump euro2, the most make ur exhaust dirtier, as long as not always.
BM 116d
Sent from Google PIXEL C using GAGT
edwinttt1978
Any diesel comes with additive like shell vpower which gives you more responsive drive?
Don’t think so. BMW specifically cautions no diesel additives in its 116d. BMW recommends Shell Quality Fuels.
greddy88
Don't think it's good for the dpf... Some cars won't move when it's clogged
IcYFl4mEz
yea its definitely not good, so in msia always make sure top up after halftank to be safe. sometimes bo bian just top a few L of euro 2 if really needed. then find those with euro 5
jamjammer
How did that work? I thought smart uses their own card. We merely uses our cc to top up that card?
Simply, TOP up the smart prepaid using Maybank family card. But first make sure u clock $1k spending then u can enjoy 8% rebates. Check out discount at Maybank website 😊
HMAN
One question: is Singapore only offered one diesel grade (Euro 5) only ? Only pump twice for my diesel car(euro 6 diesel compliance), I didn't ask the pump attendant.
2 days ago I pumped in Malaysia Petronas Euro 5 diesel, finding the car drive much smoother, quieter and better torque.
tatsit
High Honorary Member
There's a range of diesel in Sg, depending on where you get it. You can even find Euro 3 diesel in industrial sites
LaNNZ3r
Smart Petrol Station in Serangoon North Ave 5 which sell diesel (euro 5 compliance) at discount at almost 28% for members good? Sofar pumping Shell diesel for my newly acquired 2015 Jaguar XF2.2. Appreciate any feedback.
HMAN
Talking about normal petrol kiosk.
tatsit
The usual petrol kiosk sells diesel with <10ppm sulphur
Msia's diesel is <50ppm sulphur for euro 5 diesel. sulphur acts as a lubricant, which is why you can feel it is smoother. But if your car is Euro 6 and you use euro 5 diesel, it will shorten the lifespan of your engine and DPF.
HMAN
Ha-ha, affecting DPF may be but hurting engine in what way ?
Also, Euro 5 diesel standard called for 10ppm of sulphur . Where do you find the information that Malaysia Euro 5 Diesel is having higher sulphur contents yet continue to claim Euro 5 compliance.
tatsit
i work in heavy vehicle automotive industry, the engine oil is different for euro 6 as it requires more lubrication, not sure about the light vehicles. but using higher than 10ppm will shorten the lifespan of the injectors as they are more sensitive.
sorry, i keep thinking euro 5 is <50ppm when it is <10ppm. it is euro 4 that is <50ppm.
so yeah, feel free to pump euro 5 diesel in msia since it is <10ppm
IcYFl4mEz
Bro, as far as i know and been searching around. ALL diesel in SG currently is diesel euro 5 that consumer able to purchase. any lobang for diesel e6?
tatsit
this is a mistake on my part. euro 5 diesel is <10ppm which is the standard for euro 6 diesel cars
just make sure the diesel you pump into your euro 6 diesel car meets <10ppm sulfur
KeyboardWarrior
hi guys, new diesel car owner here. I understand SMART energy at Mandai/Serangoon North needs to join member/buy top up card to use. How about Cnergy at Toh Tuck Ave? Need to buy card too?
