DIY PC Rig Recommendations For 2026
deepblue_82
1. the cooler is outdated, i would recommend peerless assassin 120.
2. sorry cant help much on the ram part.
3. wd 850x 2tb + p3 1tb
4. paging NightRaven49
5.
cal316
Hi, planning to get this from invader promo. Going for invader as I do not have the time to build my new computer anymore.
I am looking for value mostly, to play games like Dota, CSGO, WoW, and also new Triple A games like Jedi Surviver, Diablo 4, Assasian Creed. At the same time I will have 3 monitors on, 1 for game, 1 for streaming shows, and 1 for discord. Can the build handle these at decent graphics and speed?
- ASUS DUAL GeForce RTX™4070 12GB GDDR6X
- AMD RYZEN 5 7600 3.8GHz
- ASUS TUF GAMING B650M-PLUS WIFI AX ARGB
- COOLER MASTER HYPER 212 HALO ARBG
- GSKILL FLARE X5 2x16GB 6000 C32 DDR5 EXPO
- WD BLACK SN770 1TB GEN 4 SSD
- ASUS ROG STRIX 750W
- LIANLI LANCOOL 216
Total damage expected to be around 2k, will update again once I get a quote.
Some other questions I have:
-Does the cooler need to be upgraded?
-Could you share more on tuning the timing for RAM? How to change and is it worth it?
-Planning to get a total of 2 + 1 TB storage. Any recommendations for which to choose?
-For the case, am not very picky, but not sure if the LANCOOL 216 is better or the LANCOOL 3.
-Do I need to add more fans?
Thank you all for your help, it’s been fun reading through the comments
Hyper 212 halo is the cooler I am using for my 5600(but mostly due to the looks and I like slim coolers better). Idle about 35-38. While gaming hogwarts legacy around 60+ Never got to 70 as thats the light to display for my rgb and it never turned red.
For the storage that default 1tb sn770 has good reviews and i would keep that for my system drive and add a cheap priced 2tb sn570(reviews also not bad) for storage for games as gen3 speed more than enough for games. If you have more budget then go for a gen 4 since the mobo supports it. I am using the 2tb sn570.
Case and fans up to you its all personal preference.
NightRaven49
yes, it should be good for 1440p and even some 4k gaming.
the cooler model is quite old, but will still do the job as the 7600 is not power hungry. still, u could request for the cheaper id cooling se224xts, which should also perform slightly better. for ram timings, tuning is done in bios, can refer to this video:
it will be very time consuming though, so judging from ur lack of time it may not be worth it, especially if u plan to game at higher resolutions where performance is less dependent on cpu and memory. if invaderpc is competent enough (which i believe they are), they should already have the 6000mhz expo profile loaded in the bios, which should be good enough. storage wise, i would assume the secondary storage is the 2tb disk. nvmes are quite cheap nowadays, dynacore offers 2tb of gen4 nvme in the adata legend 850 lite for just $125. case wise, i would go for the 216 as it offers better cooling potential for air cooling and is generally cheaper. the included fans should be enough, overall system is also not very power hungry.
cal316
msi mpg a750gf
Dynacore no stock for this liao
Asus rox strix next best choice?
Yes I got this ROG. Its made by seasonic based on the focus series but with better heatsinks and fans. Its A tier on the psu cultist list and msi is B tier. I ask for msi too first but they offered me the ROG so I guess the price is similar.
hyperfuse
Dynacore sells this tuf gaming b650m-plus WIFI board.
Issit safe to use with 7800x3d chip? Heard alot about asus boards
wtfh4x
Nowadays I don't buy cheap motherboard without watching their comparison first.
Then cross check with our local price lists to see what is good value.
In your case, looks like the MSI Pro B650M-A WiFi is almost $100 cheaper, so I would go with that.
hyperfuse
Dynacore sells at promo price of $268 with 3 years warranty by avertek. Which will u pick?
wtfh4x
I still won't buy Asus low-end boards. Very expensive for what they offer, so even on sale they're just ok value.
MSI Pro whatever Wifi is usually a safe bet for AMD, if really low budget and only using up to Ryzen 5 CPU then Gigabyte DS3H, but the price seems to have risen for B650 making it not very good value compared to the MSI. Other low-end boards usually not worth buying.
hyperfuse
I see..
At first I was contemplating to get the asus b650m riptide but that one at $240..then saw this asus tuf gaming b650m at $268.
If just this 2, which will be better? I assume the asus right?
wtfh4x
I see..
See what the video says about the riptide then decide, I think I saw it as part of the roundup.
hyperfuse
hi all, its been a while since the pc rig recommendations thread was updated, so in continuing its spirit, i have put together a new list of recommendations with more modern parts. please note, ive only used local price lists; u may be able to find better deals elsewhere, but this list will focus on brand new local stock parts. for most builds i have also left out the prices of windows keys and case, these should be spent as deemed fit (assume $150 budget for case in total price if case not mentioned, recommendations at the bottom).
cheapest usable brand new rig, total: $329
celeron g6900 + biostar h610mhp185techdeals
crucial 8gb 3200mhz cl22 ddr425techdeals
lexar ns100 128gb21techdeals
fsp hv pro 550w57techdeals
tecware nexus air m241techdeals
entry level 1080p low gaming pc, total: $481
ryzen 5 5600g + asus tuf gaming a520m plus wifi287dynacore
kingston fury beast 2x 8gb 3600mhz cl17 ddr465dynacore
lexar nm620 256gb31tradepac
value gaming pc, total: $1080
ryzen 5 5600 + asrock b550m/ac316tradepac
wd blue sn570 500gb55dynacore
powercolor rx 7600 fighter390dynacore
super flower legion gx pro 650w104techdeals
if strict 1k budget, can settle for a cheap case within the remaining $70 like the tecware nexus air m2 (again) or flatline.
mid-range gaming rig, total: $1365
wd black sn770 1tb92dynacore
powercolor rx 6750 xt red devil638tradepac
for this build tier and higher u should consider adding additional case fans, personally recommend the arctic p12 @ $12 each from mr doraemon @t258jgn.
high end gaming rig, total: $2084
ryzen 5 7600 + asus tuf gaming b650m-plus wifi564dynacore
thermalright peerless assassin 120 *157mm height57tradepac
gskill flare x5 2x 16gb 6000c32 ddr5 expo *highly recommended to tune timings190dynacore
wd black sn850x 1tb130tradepac
zotac rtx 4070 twin edge863tradepac
nzxt c650 gold130tradepac
high performance productivity + gaming, total: $3005
core i7-13700f + gigabyte b760m aorus elite ax d5783dynacore
arctic liquid freezer ii 360mm157tradepac
gskill ripjaws s5 2x 16gb 5600c40 ddr5145bizgram
sapphire rx 7900 xtx pulse *313mm x 133.75mm x 52.67mm1495bizgram
msi mpg a750gf145dynacore
no compromise pc: well if u want a 13900ks/7950x3d + 4090, then u probably arent worrying about budget, just get whatever u want :s22: these are the 2 parts u should minimally go with:
lian li galahad 360 argb (if not doing custom watercooling)196tradepac
asus rog strix 850w187dynacore
tecware flatline argbcheap, mesh intake, fits long gpus and tall coolers, preinstalled rgb fans54pc themes
cooler master mb311l argbbetter quality flatline75pc themes
tecware fusiongood alternative to nr200 with support for cheaper non itx parts77techdeals
corsair 4000d airflowaffordable, spacious, good airflow120dynacore/pc themes
lian li lancool 216good thermal performance135techdeals
lian li o11 mini air/dynamic minigreat looking case, very versatile
do note dynamic mini only accepts sfx psus
~150most sls shops
pricing correct as of 1 jul, though availability is not always guaranteed so if some parts go oos/change pricing please do sound off so i can update the relevant lists. i will also try to keep this updated as new hardware is released.
hopefully most bases have been covered, but if u have specific questions dont be afraid to ask. if u also have other recommendations that i missed out do feel free to add on :) happy building!
22 dec 22 - first revision
8 jan 23 - updated prices with non oos parts/8% gst, changed cheapest rig, revised price for work + gaming pc
6 feb 23 - revised prices and parts
15 apr 23 - revised prices and parts
18 may 23 - revised prices and parts
4 jun 23 - revised prices and parts
1 jul 23 - revised prices
Bro, any reason why tuf gaming b650m-plus is recommended?
Dynacore sells at 268 with 3 year warranty. Good buy?
NightRaven49
msi mpg a750gf
yes, but i heard also oos. if really dont have the rog strix psu, then next step up would be the cooler master xg platinum 750w, seasonic focus gx-750 or corsair rm750e in that order, based on pricing from dynacore price list.
msi is B tier.
the msi a-gf series is A tier under single rail, not sure where u see is b tier.
most board vendors should have patched the overvolt on soc by now and havent heard of any more exploding x3d chips. the fiasco was more with high end x670 rog strix boards anyway.
tuf gaming is their midrange offering, which tends to be pretty decent. asus' prime series (which is their actual low end) on the other hand, usually a hard pass from me.
if the pg riptide does not lack any features u want/need, then i would go for that. would be better also considering the exploding cpu concern on asus boards.
why nightraven recommends the Asus tuf gaming b650m-plus tho?
as hyperfuse mentioned, it is on promo. dynacore price list has it as the cheapest b650 when paired with the 7600 by far ($564 vs next cheapest $593 in the gb ds3h), which is also barely $25 more than (and hence actually closer to) the cheapest a620 combo, while having a better set of features than the ds3h and msi pro. it is also cheaper than most a620 combos from other sls shops, so overall it is no a brainer.
R6exR6
While I prefer MSI mobo, seems Dynacore ASUS mobos are noticeably cheaper. I'll choose ASUS too.
hyperfuse
Which will u choose?
Riptide b650m non wifi at $240
Asus tuf gaming b650m plus wifi at $268 ( local set with warranty but packaging in white box, because it's for their prebuilds)
Riptide b650e at $350
wtfh4x
Just checked out that specific board, does look like a big step up from the Prime. For B550 the TUF was barely an improvement so I got the impression it was just a slightly dressed up "gaming" version.
hyperfuse
There are reports that gigabyte b650 boards have the best boot times..
Msi boards have the worst boot times.
hyperfuse
Still thinking now which to get argh..
I am shortlisting,
Tuf gaming b650m-plus wifi at $268 (dynacore)
Asrock b650m riptide around $240( lazada 7.7 sale)
Gigabye b650m aorus elite at $280 ( amazon set)
Asrock B650E riptide wifi around $350 ( lazada 7.7 sale and this board has pcie gen 5 for gpu and m.2. Not saying I will use for future, but just an option)
