i dont game, just use it for office work, torrent, watching netflix/ movies. However current system seems to lag, as i have multiple tabs on chrome. Excel lags as it have tables and complex data.
Main thing is to have a smooth experience in using excel.
Below is my current setup,
AMD Ryzen 3 mobile 3200G
Microstar A320M-A Pro Max
DDR 4 16gb memory 1200Mhz
Onboard graphics.
if u are willing to diy, cheapest and most cost effective option is to upgrade ur cpu to the 5600g. u have to first update ur mobo bios to latest version, then buy the cpu and swap out the 3200g. this should provide a massive uplift in performance for less than $200: u go from zen+ architecture to zen3 which has much higher ipc and clocks, along with getting 50% more cores and 3x as many threads vs ur 3200g.
Am actually looking at the aftershock 5600 + 6700xt bundle. at 9xx.
is this a good choice for my usage? Or i should go for a better cpu instead.
i would say that is their best value offering right now, quite unbeatable even if u diy though u will have to contend with the dubious mobo and psu. the 5600 is another step up from the 5600g, though u probably wont notice the difference, especially since u are not gaming (which also means the 6700xt would be wasted). imo the 5600g upgrade i mentioned above is enough and would provide basically the same experience as with the aftershock system for a lot less money; i wouldnt spend that $800 extra vs a $200 cpu upgrade if i were getting similar performance either way.
lastly, if i want to add on storage drive to aftershock PC, can i just buy a hdd from sls and install it myself?
yeah why not, just make sure to check that there are sata power connectors from the psu, sata data cable and hdd mounting hardware/positions still available. good idea to remove it if u need to send it back for warranty though.
Is dynacore the cheapest place to diy PC ?
not necessarily, though they do have cheap parts more often than not. u can also opt for their prebuilt sister company invaderpc, which does have decent builds. but as u can see in the first post, to get the absolute cheapest u will need to shop around a few shops.
Sadly also can't find any place selling Rx 6700 XT.
ya navi 21 and 22 cards have never been very available in sls, but can try luck on carou.
wow 3200g on 34" thats a hard push...
34" but 1080p, should be no issue for 3200g.
never really seen them having great prices before. heard their customer service is top notch though, probably justifies their higher prices.
bruh
Let me know your opinions.
not too sure why u would have rog parts almost everywhere except the mobo.
What ddr5 Ram should i get? Was thinking about G.skill trident z ddr5 96GB kit 6800MHZ cl34.
u probably dont need ram that fast for ur use case, just pick whichever fits ur aesthetic taste since u clearly have no budget limitation. where are u finding these 24gb sticks? havent quite seen them around.
Anybody here using cable extension with asus rog strix 850w psu? I did mine n having issues with it. Im using the one sold by act8579.sg at shoppee. Wen i set it up, all fans are running but mobo n gpu no rgb n also no display. Switch back to psu cables, everything works fine.
have u tried one extension at a time? perhaps it could be the extension for the mobo that is faulty leading to failure to post but the rest ok.
