Door bell with camera recommendations
Yes, theres an option to hardwire it.
I printed it myself. I got a 3D printer. Cost of the material, time n electricity
May i know how to hard wire it please? Do i neeed to get additional wires/adapters etc? Or i can just leave it to the electrician and he will know how to hard wire it.
Thanks!
Have you considered Arlo? It’s available locally. I’m waiting to see what Arlo offer with touch-less technology.
I’m surprised that no one has reviewed the Arlo here.
I chat with Arlo Support before and they said they have an electrician who installs Arlo video door bells. If you buy from them, they probably will refer you an electrician.
Thanks. i did consider Arlo but didn't do a deep dive on it. Just based on youtube and online reviews, seems that Eufy edged out among the contenders.
About it's touch-less technology, maybe i'm skeptical about the tech, and i don't see much value-add from it as well.
cheg80
Anyone have an electrician to recommend for installing Nest Hello? I don't seem to be able to connect the Nest Hello to the HDB doorbell chime. Thanks.
Hidetoshi
Qoo10, $349-$38(coupon)-$50(credit card promotion rebate)
3D printed this 45deg plate
Hi this looks great... planning to get one myself...
any advice on how to get the $50 credit card promotion rebate? which CC did you use?
kuro
so many brands to choose from, which door bell with auto motion with wider angle is recommended?
Fozzy-
Hi, just to check are we allowed to drill holes outside of our HDB unit to mount the wireless doorbell?
RyanJ
The greater issue is if it can record audio or video , you need to submit a request to HDB for approval for limited given period.
yamashita
Moderator
Moderator
For those who uses wired version of video doorbell (e.g. Ring, Eufy), did you remove the existing doorbell switch and place the video doorbell over the same position?
Would the wall cavity be visible since the doorbell switch dimension is bigger than the video doorbell?
kuro
where to get Alro locally and who to look for to install?
RyanJ
Used plaster to cover over.
Does anyone actually apply for permission for such video doorbells with recordings especially the Google Nest Hello?
I did. Got myself a police report documentation, emailed and complained gao gao to MCST until they let me fix both a smart cam and smart doorbell.
RyanJ
You must have naughty neighbours.
One of the reasons I still haven’t bought a wired video doorbell and installed is - neighbours. Worry that they complain about privacy. I might end up getting the Ring Peephole Video Doorbell. If they complain, I just remove and sell it off.
Suspected was one of the Airbnb guests.
shawniiex
Buy a blank plate to cover. Drill a hole put the nest hello over it.
VodkaPear
Door bell with camera not allow meh?
Didn't know? I tot only when ppl press the bell then will on the camera, or when cam detect movement which I think can be turned off?
evq
one time event only. Anyway, this is the best vid door bell i have used.
Hidetoshi
Got the eufy 2k battery-powered doorbell... lazada had it on sale and got it at ~$250 after all the discounts... hope it is as good as how the reviews here stated!
itchying
Can we buy the eufy 2k wired model to install in sg? The voltage is different in us and sg right? Any expert advice?
taytehni
I bought this bracket from Shopee and it is able cover the original surface box for the doorbell, without doing any modifications.
Shopee link here
