e-Remote Broadlink RM-Pro
IceX
It's likely the on/off/switch is all using the same RF signal.. it's the controller on the light controlling base on the sequence of signal. So different routine doesn't matter as you still need to follow the sequence of the controller.
Sent from HUAWEI EVR-L29 using GAGT
So no choice right got to manually switch it off ?
zhifenggg
livolo rmt04 touch remote with rm pro4
hi peeps, anyone having issues trying to learn their livolo touch remote? i cannot get the new rm pro4 to learn and execute switch control from my livolo touch remote rmt04. really appreciate any advice that anyone can share.
dankoo
I have read in this thread Crestar fan does not use the 433 or 315mhz..is that true but still can control fan?
mrwirus
I wonder when will there be sale on broadlink products again. Keen to start on broadlink but wanted to wait for some promotion.
BenBen010103
Just want to check how to do a backup of all the setups in the rmpro? And how to port over all the devices already setup currently to another rmpro if lets say i intend to get a new rm4pro?
gbpdem
Hi all, anyone here able to add Decken ceiling fan remote control to RM Mini 4 or RM Pro+? Kept trying but unable to add the rf remote control to any of my BroadLink devices.
I saw another post earlier about Crestar fans having same issue. I have no issues connecting both my Crestar fans to Broadlink RM4 pro . Just add a new remote (top right) .. add fan ... "Cannot find..." .... and learn the RF commands individually for ON and OFF and Wind Speeds respectively.
singcheng
Almost time haha.. but I dun see any deals around
About $30 before shipping. I think it is a good deal, local resale price is $59.90
Posted from PCWX using SM-N960F
leonaheidern
Hi all. I just had an amasco pace Xavier 52 inch ceiling fan installed
I can't learn the RF code in the IHC and the Broadlink app. Same code works perfectly in e-control thou
Any idea how I can get it exported out and in to those apps?
I used the e-control dump and i managed to extract these
Code:
Button Name: 6| Button ID: 77 | Code: b24534000d00019f280e0e2a0d29290e280f0d2a280f0d29280e0e290e29280e280f0d2a0d290d290e290d2a0e290e29280f0d290d290e2a00000000
Button Name: 5| Button ID: 78 | Code: b25534000d0001a0280f0d2a0d29280f280f0d2a280f0d2a280f0d2a0d2a280f280f0d2a0d2a0d2a0d290d2a0d290d29280f0d2a0d2a281000000000
Button Name: 4| Button ID: 79 | Code: b20a34000d00019f290f0e290e29280e290f0e29280f0e29280f0e290d29290e280f0e290d290e290e290e290e290e29290f0e29280f0e2a00000000
Button Name: 3| Button ID: 80 | Code: b22834000e00019f290e0e290e29290e290f0e29280f0e29290e0e290e29290e290e0e290e290e290e290e290e290e290e29290e290e0e2a00000000
Button Name: 2| Button ID: 81 | Code: b25234000d0001a0280f0d2a0d2a280f280f0d2a280f0d2a280f0d2a0d29290f280f0d2a0d290d2a0d290d2a0d2a0d2a0d2a0e29280f281000000000
Button Name: 1| Button ID: 82 | Code: b25434000d0001a0280f0e2a0d29290f280e0e2a280f0d2a280f0d2a0e29280f280f0d2a0e290d2a0e290e2a0d290d2a0d290e290e29291000000000
Button Name: Power| Button ID: 83 | Code: b23134000d00019f290f0e290e29280f280e0e29280f0e29280e0e290e29280e280e0e290d290d290e290e290e290e290d29290e0e29290f00000000
Button Name: Reset| Button ID: 84 | Code: 26004a005c0008d85b0008d95b0008d95c0008d85b0008d95c0008d85c0008d85c0008d85c0008d85c0008d85b0008da5b0008d85b0008d95c0008d95a0008da5a0008e81207180008f758000d050000000000000000000000000000
Button Name: 1 H| Button ID: 85 | Code: b29434000b0001a0270f0d2a0d2a280f270f0d2a270f0c2a270f0d2a0d2a270f270f0d2a0d2a0d2a0d2a0d2a0d2a0d2a280f280f270f0d2b00000000
Button Name: 4H| Button ID: 86 | Code: b23334000d0001a0280f0d2a0d29280f280f0d2a280f0d29280f0d290e29280f280f0d290d290d2a0d290d290d2a0d2a280e280f0d2a0d2b00000000
Button Name: Repeated| Button ID: 87 | Code: b23d34000d0001a0280f0d290d29280e280f0d29280f0d29280f0d290d29280f280f0e290d2a0d290e290e290e290e290e29280e290e291000000000
Button Name: Light| Button ID: 88 | Code: b20934000C00019f290e0e290d29280e280e0e29280f0D29280e0e290d29290e280e0d290d290d290e290e290d290e290e29280e0e290e2a00000000
Posted from PCWX using G8342
leonaheidern
Ok nevermind figured it out.
Look for /internal memory/broadlink/newremote/databases the following 3 files
1)jsonSubIr
2)jsonButton
3)jsonIrCode
installed python 2.7 on my windows 10 pc
https://github.com/NightRang3r/Broadlink-e-control-db-dump
Select the ID For my Pace Fan
Downloaded Broadlink Manager from here
https://community.home-assistant.io...way-to-learn-and-send-ir-rf-commands/58770/68
Used this to convert from the econtrol code to base 64 http://tomeko.net/online_tools/hex_to_base64.php?lang=en
Edit the Broadlink Manager Commands.json file in notepad
C:\Users\Username\AppData\Roaming\Broadlink to include both econtrol and base64 codes for each button
Connect Broadlink Manager to the Broadlink RM Pro 2
Reopen Broadlink manager and Broadlink app on the phone and learn the commands using the Broadlink Manager by pressing send command on the broadlink manager when the Broadlink RF Learning app is opened.
At least this gives me a way to buy a Broadlink RM Pro 4 and restore my fan control over from cloud
ChewAhSoon
Hi all, can I check for Broadlink TC2 smart switch. Does the LED light up when it is in the off state? Or does this function only works with the neutral wire?
Also in SG we need to use the UK version right?
huask
Door alarm sensor
Hi! Is there any other brands then Broadlink that door alarm sensor can work with Broadlink RM4 pro?
chesterchen
According to the Shopee Official Broadlink Store:
Hi, unfortunately, you can't copy your previous settings over to the RM4 Pro. You'll need to relearn everything from scratch
pushtopen
Hi, sorry still a little bit confused with the function of the rmpro4. For air cons in other rooms other than the living room, can I sync the IR with the rm4pro and it will work as intended or does the rm4pro need to be in sight of the IR sensors on the aircon for it to work?
Has anybody tried syncing it with KDK ceiling fans as well and any success if so?
Do I require more than 1 rm4pro to be placed in each room for it to work?
Thanks for the help!
shawniiex
IR cannot pierce room.
Buy the mini for each room you want use aircon for can already.
