e-Remote Broadlink RM-Pro
singcheng
Have linked my BroadLink to Google home.
However it does not seem to switch on or off the ceiling fan lights via voice command on Google nest mini
No issues with siri though
I have no problem controlling my ceiling fan (via broadlink) with Google Home.
Did you link "ihc" or "broadlink" (blue B icon) in Google Home?
Posted from PCWX using SM-N960F
IceX
I used broadlink app. Never used ihc before.
I can switch on and off my ceiling fan with Google home. It’s the ceiling light that I can’t seem to switch on or off. Previously done it via BroadLink app and there’s no issue.
When I issue voice command via Google home to switch on the ceiling fan light,it says it is not set up yet
singcheng
I can switch on and off my ceiling fan with Google home. It*********s the ceiling light that I can*********t seem to switch on or off. Previously done it via BroadLink app and there*********s no issue.
Is your Ceiling Fan Light showed up in your Google Home app?
singcheng
No leh..how to set it up ah?
This is my screen
Only your Ceiling Fan is in Google Home, the light is not.
How you setup the light in Broadlink? Is it based on IR or RF or wifi?
One thing you could try is: unlink your Broadlink from your Google Home (so that your Ceiling Fan is no longer in Google Home) then re-link the Broadlink to your Google Home (you should see your Ceiling Fan and, hopefully, the Light).
If all fail, then you screenshot the Light in your Broadlink app so that we could help further.
IceX
Hmm I set up via RF
I try to unlink BroadLink from google home and Link again and all I saw were only these few options
The light as part of my ceiling fan in BroadLink app
sellun
Try to create a scene on your broadlink for on light and off light. Then on Google home you should be able to create a routine and set the command to activate the respective scene in your broadlink..
Sent from HUAWEI EVR-L29 using GAGT
sellun
I'm using IHC but I think broadlink app can do it too.
Example for you..
Elon Jobs
I’m using a similar set up as yours- a ceiling fan with a built-in lights and RF remote control. When you tell Google Home to turn on fan, it will only turn on the “on” button on your IHC/Broadlink app as you have screenshot. Google Home can only turn on or turn off the fan, it is unable to turn on your fan light.
So if you want to turn on the lights, you have to create a scene like another brother has explained and then crease a new routine under Google Home.
Alternatively, you can create another lamp on IHC/Broadlink app, and set it to learn the RF for on and off for your fan lights, then place it on whichever room you want on the Google Home app, say for example, living room. So when you say, turn on living room lights, it will turn on that particular lamp. But do take note- if you have multiple lamps placed in the living room, Google Home will turn on all the lamps in that particular room.
Vulpix
Moderator
Moderator
I think it's easier for those who are buying new fans to just get one supported by Smartlife. Less hassle, can consider PO Eco and other brands.
prata
Hi anyone managed to connect RM 4pro with Tmall genie.
Any YouTube guide to teach me how?
Which icon should I choose in tmall genie app?
tvkal
Hi to all, new here and i want to ask
I have already installed a broadlink RM4 mini and another one Broadlink RM4pro RF433mhz+IR device and I turn on and off air conditioners and TV set and I also have room temperature and humidity information.
1. It is true that broadlink can detect some door window sensors 433mhz? The Sonoff SW1 RF? (I tried this but i failed). Any other brands and types ?
2. If this is valid, I want the broadlink to turn off the air conditioner when someone opening a contact. Is it possible?
Thanks in advance
singcheng
Are you using Broadlink app? If so, search for it in your Tmall app:
If you use ihc app, then you have to search as below:
Elon Jobs
Which method did you use? The scene method?
Thanks elon and sellun!
It worked.
May I know how about turning off the light? Cause the on and off button is the same
I just have to voice out the same command right ?
Elon Jobs
Then you can create two routines- one for when you say “turn on fan lights”, another for “turn off fan lights.” Both routines will activate the same scene, but then you can have Google assistant reply “turning on fan lights” and “turning off fan lights” respectively.
One tip- your command to activate the scene, try to make the last word plural instead of singular i.e. lights instead of light. Google assistant response better to plural.
Yes the scenes/routines method
IceX
Thanks for the plural tip.
I’ve tried creating two routines but it does not seem to work.
Not sure if it’s my fan remote.. it has three different lightings and I will press once to switch it on, once more to switch it off and once more to switch to another lighting.
Elon Jobs
Oh if that’s the case then I can’t help you coz my lights is a straight forward one button on and off.
sellun
It's likely the on/off/switch is all using the same RF signal.. it's the controller on the light controlling base on the sequence of signal. So different routine doesn't matter as you still need to follow the sequence of the controller.
