Yes there are various standards, for example certain gates and cars using learning codes etc. But for your standard light switch, the rf 433 mhz is quite generic.
Just try! Only $3...
i managed to set up the link from google home to my ceiling fan.
however i have to use the commands "activate fan on", "activate fan off"
is there any way that i can change the commands to "turn on fan", "turn off fan"
Tried to use IFTTT but i cant find broadlink in their service
If you don't need cloning, this is cheaper and better.
https://www.aliexpress.com/item/433...-953c-c41c4a3fd9ec,scm-url:1007.13339.90158.0
Use "shortcut" in google assistant settings.
Hi hi, i got the RM pluging..
1. Do i have to paid for the tasker app separately?
2. Does it conflict with IHC? previously i tried RM pluggin. End up my alexa start to read new buttons from RM pluging, ie cannot find my new device/scene from IHC.
Up, l have the same issue. On ihc, RM pro can only turn on the light but not ceiling fan. I'm using kdk U48FPAnyone managed to set up different control for fan and light in broadlink for those ceiling fans with lights?m (single switch..) thanks!
Sent from OnePlus A3000 using GAGT
Unless u using rm plugin method... Ihc tv template uses learn remote way only, Ur TC2 doesn't have a remote to learn... U can try get a cheap 433mhz remote and pair with ur TC2, afterwards let it learn as tv template in ihc... Den shld be fine
But I understand that in ihc when creating tv template to learn the buttons, rm pro is waiting to receive ir signal to learn that's why I am not able to create my tc2 switches as tv template. So by getting the 433mhz remote to pair with my tc2 switches, how do I get the tv template buttons to learn from the remote as if I am not wrong the remote also send out rf signal only after pairing with tc2.
Tks, works now. Realize I have to set as separate on and off buttons on ihc even though it is only one on/off on remoteU can turn on anything. Simply configure them as light as well.
Hello @hexanol! Did you use the Broadline e-Control DB dump script to extract the codes from eControl? I realise that there is only 1 set of code when I thought the eControl has a different code for ON and OFF actions?i followed the instructions given on the website to install on the SD card. Then just added the line to add broadlink in configuration.yaml.
My raspeberry pi is usb powered by my router.. so both is always on and always connected to my wifi.
Button Name:
Button ID: 9
Code: b20a44000a0001450a1f0a1f0a1f0a1f1f0a0a1f0a1f1f0a0a1f0a1f0a1f0a1f0a1f1f0a1f0a1f0a0a1f1f0a1f0a1f0a1f0a1f0a0a1f1f0a0a1f0a1f0a1f1f0a0a1f0a1f1f0a0a1f
Base64:
sgpEAAoAAUUKHwofCh8KHx8KCh8KHx8KCh8KHwofCh8KHx8KHwofCgofHwofCh8KHwofCgofHwoK
HwofCh8fCgofCh8fCgof
