e-Remote Broadlink RM-Pro
homeagenius
Home-A-Genius Smart Home Solution
Hello All!
We've been hard at work to create a smart home hub that integrates various local mainstream smart home brands (such as Xiaomi, Broadlink, Philips, TP-Link, Alexa, Google Home and more) into a single platform.
We have called this platform Home-A-Genius and we believe it is now ready for prime time.
Currently we're having a launch event to win a $800 discount off our All-in-One Smart Home PRO Package. Check out our Facebook for more details...
Basically, the package will automate your ceiling lights/fan, air-conditioners and more. Easily voice control your smart devices from anywhere at home. Monitor and automatically record videos of your love ones or check on visitors at the main door with an IP Camera.
There are also several other interesting features that we offer, so feel free to check us out and feedback us at any time. Or PM us if you have any questions!
Cheers!
Home-A-Genius Team
tangrick
Who's using RM Pro with Livolo rf switches and able to make them work consistently? I can learn the commands from the remote, but it never works consistently. Sometimes it works, but more often than not it takes repeated tries to turn on a switch. The Broadlink TC switches were lot more consistent in this aspect.
I am using RM Pro+ with livolo switch + google home. They all work very well together. To record livolo signal into RM Pro+, I believe you need the key chain remote. I bought them from lazada, very cheap since the local store that sold me the livolo switch didn't provide the remote.
Initially I had so much problems to get them to work but once you know what to look out, it became easier.
I have 3 lights switches and to control each switch I need 1 keychain remote for each switch. So in the end I have 3 remote. I pretty sure that each keychain remote with button A,B,C,D has unique frequency to pair with the switch. So I can't use 1 remote only to record into RM Pro+ to control all 3 switches unless I want all of them to turn on when I can on 1 button.
RM Pro+
- I used ihc on my iPhone
- I created UserDefine
- To create a button,
- click +
- learn RF (this is the tricky part)
- instead of hold the button on my keychain remote, i pressed 1-2 seconds, let go and immediately, pressed 1-2 seconds and repeat until it learn the frequency.
- once it learned then after that it is easy, just press the button again and it will learn.
- after that just test it and sometime it works very well and sometime it doesn't
- if it doesn't work properly for example...intermittent...then rm pro+ didn't learn correctly or signal not strong, I would repeat the steps again. I am not sure which steps caused the problem the frequency learn or the last press button, so sometime last step of button press..i might pressed a little longer like 1.5 sec, instead of pressed and let go.
IHC
After that I would create Scene in IHC, example Ceiling Lights On
Link/Sync Broadlink in Google Assistance/Home
then I will test the command "Activate Ceiling Lights On"
to see whether it work. If it does not, I just redo the re-learn process again in IHC. Once they all work using IHC app and Google assistance. It will continue working well. No more issues.
Hope this help anyone using Livolo and RM Pro+ and Google Home. Good Luck!!
tangrick
Yes. They worked well together but some how the remote and fan had to be closer than normal. If you have issue after recording, just test it near to the fan.
Mng85
My ihc app suddenly gt script error.. and unable to download profile info.. any one face this issue to? Only problem with andriod but not ios... strange...
luvselina
Hi guys,
I would like to ask if anyone has managed to pair the broadlink rm pro+ to the following:
1. Singtel mio tv set top box
2. Xiaomi 65" TV3s (controlled via IR, got a physical remote for it)
3. Crestar ceiling fan with light (controlled via rf. Got a physical remote for it)
Went thru 30 over pages in this thread but couldn't find any answers lol, hope u all can help me out here :)
hexanol
Hi guys,
Not sure of Singtel box, but the rest as long as normal IR and RF, should be able to. I know starhub box (samsung IP TV) cannot.
Mng85
Do note that for IR it had to be within visible range.
malkian85
fanco remote with broadlink RM pro
Hi guys, need your advice please. I just bought a fanco ceiling fan with remote control and tried to control it using my RM pro. but it cannot detect any signal and cannot learn when I press the fan remote. any idea what is wrong?
anyone here using fanco ceiling fan and what RF frequency does the remote use? pls help. Thanks.
Alphas
Has anyone tried having both Amazon echo and Google home mini connected to the same RM PRO. Does it cause any issues or incompatibility?
batniss
I am using it. Fanco and RM pro. It works fine.
However these 2 days my broadlink cannot be detected by google home even when the device is available in ihc and google home app
Jasyu
Guys looking to automate my water heater using a broadlink RM PRO+ but I cant seem to find a 20A switch. Anyone successful in doing it?
edwin56
anyone got problem/issue just even trying to sync google home with "Broadlink Smart Home", where it loads a google 401 error "client does not have permission to the requested url"
those who had it working, can help to unsync broadlink smart home from google assistance and link again?
infernolord
Anyone know if the broadlink device can tell if it is raining using the humidity sensors?
Any other app that i can use? Detect rain, if raining close my window curtain/bind?
Neal Caffrey
Uppzzz would like to know too. my only worked for ceiling fan light but does not detect the speed as well.
medscy
hi,somehow I can't upgrade the firmware of my RM pro+. It keeps saying "network error. Please check your network connection." I've swapped connection to the Wi-Fi hotspot on my mobile phone and tried using eControl to no avail. Anyone encounter the same problem? Because of this failure, I can't add devices to my RM pro+ in iHC. :-(
BenBen010103
How to add the broadlink tc2 switches in e-control app? I tried many template but it seems it just detects ir signal.
shacboi
I'm having amazon echodot , using ihc tv template for voice cmds.
and at the same time, google-assistant via HP, to giv light template cmds to RM pro.
no issue,
shacboi
hi, try scan the freq first , after that den click on the 'lern single' to learn the remote... it should work. i'm using Fanco iCon model, 433mhz.
