e-Remote Broadlink RM-Pro
singcheng
Seems like LIVOLO comes up with a WiFi & ZIGBEE switch now, without the use of neutral wire?
SG$ 41.59 16%OFF | Livolo APP Touch Control Zigbee Switch, WiFi Home Automation Smart Control, Work with Echo,alexa,google home
https://s.click.aliexpress.com/e/cNMnh3TE
You missed this fine print...
Posted from PCWX using phone.
Creator of OEM Comparison Chart & Plan Calculator.
Ohm user since April 2018.
Alibeckham
I recentl just installed a new wall touch switch with RF (Sensoo brand), however whenever i on my kdk ceiling fan to max speed (i.e. 9).. the sensoo switch will auto off.. if i use at lower speed.. this issue doesnt occur.. anybody got such experience? It is such touch wall switch is not suitable for ceiling fan?
Elon Jobs
Anyway think finally hav another water heater switch now... Using smartlife app. Yes la!
SG$ 23.87 50%OFF | EU WiFi Boiler Water Heater Switch 4400W Tuya Smart Life App Remote Control ON OFF Timer Voice Control Google Home Alexa Echo
https://s.click.aliexpress.com/e/QT1emyu
Wah so cheap! Too bad I already installed my 20A eTouch. If not this will be a cheaper option.
shacboi
Good find, seems that a few customers from Singapore bought it too from the reviews.
Yea, chat with the seller from AliExpress one.
Switch using SmartLife app, one of the better apps around.
Think good enough to try out, EU standard though. :s22:
medscy
Anyone still using eControl and finds it unresponsive especially at night around 10pm? Interstingly, iHC is ok.
KennyKhor
Aqara Switch
Anyone using aquaria switch ? Is it 2 way communications ( able to know the smart switch on/off status ) ? . Is it communicate with Google Assistant ?
Thanks
zoneguard
Thanks
Aqara is not related to Broadlink at all which is what this thread is about. Aqara with neutral switch has status whereas the models without neutral has no status since no power.
Google Assistant has no direct relation with Aqara. Broadlink app (IHC) has GA support.
I would suggest you read up more on home automation or watch Youtube videos.
shacboi
For wall switch that comes with the capacitor, how you guys connect? Who has picture to show? Thanks in advance!
shacboi
Haha. K the capacitor is suppose to put at lighting the connection. Abit troublesome like this.
In SG our voltage is 220/240v, actually can use 220v switch oso right, I googled and find some help online.
Therefore the capacitor is only if lights flicker den need to use, not lik mandatory?
Sorry to ask, me not electric trained.
Why not contact the seller? There are so many types of wall switches...
zoneguard
230V 50 Hz.
For wifi no neutral switch , capacitor at 1st gang lighting point mandatory. At least those brands (Burnett, Minitiger) I know need it.
For Broadlink TC2 RF switch , seller will tell you newer version (2019 onwards) has improved design so capacitor is optional at the lighting point if no flickering.
For some other RF switches, usually seller will recommend installation of capacitor due to switch design. Eg Funry.
Hence it is best to follow seller's advice - which was what I said in the first place. Really many variety of switches.
:s8:
Hainan
There's a IHC update, V 1.9.26. Anyone updated? Do we need to backup anything before upgrading? TIA
