e-Remote Broadlink RM-Pro
shacboi
Okok, noted.
BTW anybody here using the 2019 TC2 with inbuilt capacitance? Is it reliable?
Google_assistant can identify with the switch tamplate and on/off? Without relying on lamp template?
230V 50 Hz.
For wifi no neutral switch , capacitor at 1st gang lighting point mandatory. At least those brands (Burnett, Minitiger) I know need it.
For Broadlink TC2 RF switch , seller will tell you newer version (2019 onwards) has improved design so capacitor is optional at the lighting point if no flickering.
For some other RF switches, usually seller will recommend installation of capacitor due to switch design. Eg Funry.
Hence it is best to follow seller's advice - which was what I said in the first place. Really many variety of switches.
:s8:
mosprockett
Okok, noted.
To confirm is latest broadlink tc2 2019 the BEST option for no neutral wiring?
Also:
1. what level led watts will kana flickering problem?
2. For broad band tc2 no neutral, does it mean no on / off status?
Thx
Posted from PCWX using GM1910
xenocide
anyone using Tmall Genie?
Are you able to link with RM Pro?
i tried to add RM Pro to Tmall Genie but was directed to a "Domoticz" website
which i have to sign up and setup.
Domoticz is like another HAS... anyone using this?
Thanks.
cscs3
For wall switch that comes with the capacitor, how you guys connect? Who has picture to show? Thanks in advance!
Usually the capacitor is to connect at device side. This provide a bypass so that those electronics in switch continue to get some power when it is off position.
Some device, eg certain type of LED driver. Already has capacitor build in. Then you do not need this additional capacitor.
shacboi
yes, i figured it out after chatting with some sellers.
thanks for the info!
shacboi
Also:
Thx
Hi there, not sure that was a question for me ?
anyway, i can share what i know... , im using non-neutral wire switches as well, the brand im using is livolo.
So far they didnt give me any issues... but livolo switch are toggle-mode, meaning if u pair with a remote, the same button toggles it on when off, and toggle off when on.....
some other brands of non neutral switches available right now are Funry , MiniTiger, Broadlink TC2 ...
but i have follow the forum for awhile and there hav been complains on Broadlink TC2 switches have issue, lik spoilt after awhile or so, but recently i check with a seller in SG Carousell, there seems to hav a new 2019 enhanced TC2, therefore im asking ard if anybody have tried and whether the realiability improves ?
To try answer ur question,
(think TC2 have the 100w per button restriction, and so mayb if too high watts will kana the flicker ? I'm not sure as i didn't encounter any issue with livolo switches so far )
(yes, almost all non neutral wire switches doesnt have feedback, which u cant see from app whether is it on/off in real-time, but i understand the new switch MiniTiger have eWelink/SmartLife app control as well, then if yes, it will have feedback status i believe, but i don't realli see anybody using this switch yet for now)
Hope it helps! :s13:
hotpick
Thanks.
I assume you oredi setup the RM Pro with IHC, from the Tmall Genie App, just need to add/link the broadlink acc same as ur IHC - same way like GH. Once ur broadlink acc added, u will see RM Pro and all other devices if any from IHC appear at Tmall Genie app .. found that for Tmall Genie to control , the device location and device name shd be in chinese (done at IHC)- no issue for GH to recognize that too if u have GH oso... That's how the rm pro works for both my Tmall Genie and GH.
xenocide
i'm using e-Control rather than IHC though
add broadlink acc to Tmall genie? hmm mind telling me where is this option?
cos i can only add device...
thanks!
hotpick
thanks!
Based on the current app version,
Open Tmall Genie app->我家->添加设备->跳过-》at the top search bar key in "Broadlink or 博联“ ->select any one of the appeared of Broadlink RM Pro->账号绑定(for ur IHC acc not econtrol), proceed and done.
Prior to link with Tmall Genie, make sure u have setup your IHC acc and linked with rm pro.
xenocide
hmm thanks i will switch to IHC and try
hotpick
np, both IHC and eControl can coexist and can work independently..u may use the backup and restore function of eControl to backup and restore all its existing linked remote ctrl just in case.
ra[g]e
Hi, need some help from the experts here.
I just installed the Broadlink TC2 switch. It pairs and works fine with the faceplate off.
However, once I put the faceplate back on, the both switch lights keep blinking like its in pairing mode, and once the blinking stops the switches are non-responsive.
Everything works fine with the faceplate off and pairing is successful.
Anyone encountered this kind of issue before and is there a fix?
ray0006
Think i have something similar before with livolo switch, seems to happen when the faceplate and the base doesnt fit properly. Normally I just remove and put back in several times until the alignment is perfect then it will work fine from then on...
ra[g]e
I managed to fix this by power off the mains, putting the faceplate on, and turning the power back on.
My electrician installed the TC2 switch without switching off the mains, so that was the mistake here that caused the issue when the faceplate was put on.
This also fixed a separate bug - previously I was not able to turn on/off both my lights at the same time, so I had to space out the commands - now I'm able to.
DG8831
hi all, sorry for the noob question
Does anyone have experience in successfully connecting RM hat products to Singtel's Askey system?
I know that RM can only connect to 2.4ghz -- but I'm not sure how to create a separate network on Askey. Any advice appreciated, thx!
zoneguard
Is this guy a licensed electrician (LEW) or Superman? Work on live circuit without engaging the circuit breaker?? :eek:
chesterchen
Dear all,
Just started renovations on my new house and having the wires pulled (including neutral).
Looking for recommendations on which brand of switches to go for?
Have GH in every room and wish to control the lights using voice.
Also have requirements for several lights to turn on/off based on time.
Thank you,
Chester
viix
Dear all,
Thank you,
Chester
SMART Light: yeelight, Philips hue
SMART SWITCH: Broadlink or AQARA or MCO with respective hub, Else get the wifi versions like Sonoff or MCO or TUYA compatible switch
Timer function depends on the App or hub or clould setting..
AwfullySmart
Dear all,
Thank you,
Chester
As you already have neutral wire installed, I'd suggest skipping those stateless RF switches and go with either Zigbee or Z-Wave switches. They are more reliable (Mesh network) and is stateful (it reports whether the switch is really ON or OFF).
Wifi switch would be another (cheaper) alternative.
If you require further advice or setup your smart home, we can assist you.
ra[g]e
Dear all,
Thank you,
Chester
I'm currently using a Broadlink TC2, does not need neutral wire. I was under the impression that the control for this would just be "toggle", i.e. that the hub and Alexa would not know the state as to whether the switch is on or off.
I did some extensive testing just now. I told Alexa to turn the switch on, manually switched off the light, and told Alexa to turn the switch off. Nothing happened. Told Alexa to turn the switch on and the light turned on.
The TC2 may not be able to display the "state" of the switch, but there are two separate "commands" for turning "on" and "off" at least.
Not too sure how knowing the "state" of the switch will improve my home automation experience compared to what I've set up now.
