greythorne
- Oct 25, 2006
Please PM me thanks.If you need recon unit let me know, I'll pass you my workshop contact.
Same for alternator.
Hey I driving swift too..had same prb too. I change to recon starter, $250 include labour, yr battery should be OK rite?
Alternator failure can be detected easily with an OBD gauge. Would recommend drivers to get one and monitor, once there's a voltage drop under 13v.. probably it's time to change.
Mine was quoted $280. Today brought to workshop. Mechanic checked and true enough got the click sound.
Battery is ok. I checked myself using multimeter.
Anyone will do. Can just get a cheap one.Which OBD gauge you recommend?
Mileage 161k km.
So normally mechanic take the faulty starter motor or give to to the customer?
Anyway it seems like my car the starter motor has carbon deposits. May be the reason why this seems to be a random issue.
