Etiqa’s ELASTIQ and SAVE3?
rkesin
Looks like policy pal gives better cash rebate for referral program. Anyone has the referral code or link? How does it work?
Etiqa direct can be better if u need to buy other insurance products as they will give you a credit reward of 0.5% of the premium. So if it’s 50k, that’s $250 credit can use for car insurance etc. but if you want actual cash, policy pal is better
maumu
hello. can I check with those who've joined... is your name reflected in the correct order as per your NRIC/passport?
for mine, they published it as (first name) (last name) so instead of Tan Ah Kow they put it as Ah Kow Tan. is yours the same? did you all try to change it with them?
want to bump this up again to check with fellow policy holders. is your name reflected correctly as per your NRIC?
I've been asking them to update the policy documents but they said they can't generate again even thought they have "amended the name under our system". can trust them or not? why cannot regenerate the policy document?
my 14-day free-look just over. quite cui their customer service... send them message via TiqConnect, they don't respond one. After a few days must WhatsApp them.
JialatThisOne
Their WhatsApp is must faster than customer service. The WhatsApp team should be able to do
F1ngolf2012
Thanks for bumping this up. Would like to know if others also face the same issue and if this needs to be fixed.:s11:
kkgkkg
Etiqa Referral Code
If anyone has a referal code and is willing to split your earning with me, pls pm. Thanks.
PS, just cleared my inbox. Pls pm. Thanks.
maumu
thing is, the WhatsApp team will ask you to send a (secured) message via TiqConnect to get them (the TiqConnect team?) to follow up.
the WhatsApp team don't have the ability to fix such things. they can only help you to escalate the matter, to hasten the process.
so i'm not the only one... apparently the latest info the WhatsApp team said is that they will email me a 'letter' clarifying my name on the policy document, to attach if necessary should any legal matters arise down the road.
quite crap i say. they insist they cannot regenerate the documents once it's created during the initial registration.
on another note, is it true this 'account' is protected up to $70k by SDIC?
JialatThisOne
Hi your inbox is full. But you can sign up with Policypal to get full rebates directly yourself (instead of splitting earnings)
If you sign up via this link you can get $10 from Policypal:
http://refer.policypal.com/c/SIGNUP
After that, you can buy Elastiq from Policypal.
For $5k-$9k deposit, you get $10 from Policypal
For $10k-$25k deposit, you get $20 from Policypal + $50 from Etiqa
For $26k-$50k deposit, you get $30 from Policypal + $100 from Etiqa
Cheers!
F1ngolf2012
I do not have any policy with Etiqa now. Singlife has the same thing as Etiqa and below is what Singlife said on the "mismatched" name. Not sure if this would help.;)
Singlife: Yes. It's just for the system is captured your name mismatched. Your name is recorded with your NRIC, any claims in the future we will follow by the account name referring to NRIC.
Singlife: It shouldn't be an issue as the system has your recorded NRIC.
oceanicmanta
i just applied via PolicyPal ... I noticed that the PP application process, the default name format is "Ah Kow TAN" ... I manually changed it to TAN Ah Kow.
My Etiqa policy docs show the correct format ... anyways, i dont think it is a big issue since NRIC is on record too
SDIC PPF shld be 100k per insured for universal life plan
Joseph99
Hi, anyone know if i sign up today but top up the amount tmr, will i still be eligible for the rebates ?
tan8888
Hi, when I try to apply, saw 2 fields to enter. What can I enter for promotion and federal?
Anyone can pm me for the promotion and referral code?
Thanks.
What is the save smart promotion code? Or the save smart is auto given?
Utonian
Thanks.
Hi, have pm'ed you
IcYFl4mEz
so in short, is this like singlife? interest paidout on monthly basis, but locked for first 3 month?
transfer via bank any time?
Utonian
i would think is better than singlife if you need to deploy more than 10k.
interest accrued daily, credited monthly
lock in 90 days then can withdraw when you want via paynow/FAST
sheristopher
If signup from policypal, is it safe to transfer money to policypal? Can transfer directly to Etiqa? How?
oceanicmanta
after completing application, u will get an email from PolicyPal to make payment to a OCBC account (payee = PolicyPal)
after payment, u will get email from Etiqa with your policy documents and separate email to activate Etiqa online access.
You will see your docs via Etiqa online
for me, everything was completed within 1 hour after application via PolicyPal
