Exchange Rate - Part 2
s-ghost
High Honorary Member
24+ can. But it was hovering close to 25 just few months back.
wasted no change to keep
anyway trust card just need activate for overseas use then can withdraw liao? what ATM can withdraw and how to tell the rate? possible to know the rate before flying there so can decide if want to change here or withdraw there?
twosix
I use xe.com to check the rates. Megabank, bank of taiwan are free. Megabank atms can ve easily spotted in the airport.
s-ghost
so i guess it's really more worth it to withdraw there given the rate it dropped to now?
any cap to withdraw by the way?
calkel20
I check using mastercard exchange
Now withdrawal should be better at 24.3 for today.
twosix
Use the cards to withdraw from the atm is more worthwhile. Dun use the exchange counters in the airport. Use Trust or amaze cards on the weekends to withdraw or pay as they dun have weekend tax.
Joelleyuan
wah that's very little
so if say swipe credit card, it would be same rate as withdraw?
If you're using TRUST card to withdraw from ATM, there is NO cap. You can draw as much as you want from your "savings account".
Take note NOT TO choose credit or other options except "savings account".
as for how to check the rate you're getting, I'll look at xe.com for a gauge, if rate seems ok, then i draw the minimum amount (twd100) first, so that trust app will pop up notification and i log in to check how much sgd being deducted. from here i can know exactly what is the rate I'm getting "today". then proceed to withdraw more.
s-ghost
oh that makes sense
and credit card payment, the rate should be about same as ATM withdrawal?
Joelleyuan
oh that makes sense
yes, should be around the same rate BUT i think somehow there seems to be a bit of difference at different shops or when using uber.
anyway, it's still definitely much better than using money changer.
s-ghost
Did u read their websites or faq? They're the same rates. Only is got atm fees or not.
seems like can change $50 $100 sgd here, then the rest go there settle
