Galaxy Note 5 sleeping issue
Do you guys who owned a Galaxy Note 5, does it had the sleeping issue
  • Yes, I had the sleeping issue
    Votes: 140 77.3%
  • No, I do not encounter at all
    Votes: 41 22.7%
  • Total voters
    181
renfred89
ok i saw got the below 2 fw :
N920IDVU1AOH6 - H6 newer
N920IDVU1AOH2 - H2
Maybe u all can advise ... Settings>System>About ... Build number
H6 - sleeper
H2 - ok ???
if H2 all clear, 2moro i go get mine=:p
how sure are you to get the H2 firmware? LOL
tkl23786
Well, if all the H6 firmware are sleepers (which it seems to be the case for now), then H2 firmware are most probably the non-sleepers, fingers-crossed...
You can flash firmware using Kies if the firmware is the official ones from Samsung. No need to use Odin.
Chevalier
ive gone one step further and flashed the australian H2 firmware....lets see how it goes....if its good, i'll flash the H2 SG Firmware onto my wife's set
ATN888
Thanks a million for test! so far so good?
will wait for your update:)
jnashville
I'm on h6, sleeper till cannot sleep
My 64gb is on h6 and has the sleeper. I have another 32gb that has upgraded to h6 like 3 days ago but never experience any sleeper issues before n after the update.the 32gb is using the s view cover with the nfc chip to wake the phone.
renfred89
Wouldn't that void your warranty if your phone screw up?
sammobile houses the official firmware from samsung. what sammobile does is that it pulls the official firmware from the samsung server and store them on their own server, then charge you for the service. of cos you can choose to download free, but the terrible download speed will probably let you spend 6 hours or more downloading a 1-2gb worth of firmware.
however if you choose to flash the firmware out of your own region, then you phone might be bricked and service centre can simply charge you for the repair..
hairymonster
Hi guys. I think I might have found the solution.
Try this.
Go to settings-application-application manager
Under application manager, scroll to "all" on the right
Find touchwiz easy and touchwiz home. Clear data and clear cache. That's it.
renfred89
Try this.
wah my arrangement of icons will all disappear leh...
Kel1ng
Try this.
Nope already tried that last week.....did not work.......but frequency of wake up lag reduce from 2 to 3 times a day to 2 to 3 times a week......
renfred89
technically, once you do a factory reset, no need to clear cache already..
anyone tried different themes? maybe its the theme.. :D
