Gear S2
toyomi
Looking for bands also. The original so ex..$68... How much u bought yr band for?
Anarky
USD 9.60-ish for black stainless steel strap. Free shipping and got back SGD2.16 in cashback (from 3rd party website which i shall not name in case mods give me warning).
But like I mentioned earlier.. nvr bought from aliexpress before, so just testing water since the price is so much cheaper than qoo10 or lazada. Will update when I receive the goods
marcus70
think u will be in for a long wait :D:Dshould buy from taobao but probably more ex,to buy from qoo10 must use code
evq
Just wanna share I got mine from Kasia mobile on Sunday for $465.
Staff was patient with me as I checked for scratches and if everything was in the box (probably since I'd already paid before they let me break the seal to check the contents). Satisfied with my purchase so far.
Now I've just got to tahan the wait for my strap and screen protector bought from aliexpress (12 USD total), fingers crossed they won't take 60 days to deliver.
normal or classic?
bagyidaw
Any local stores carrying gear s2? Challenger store only got white sport and classic only.
It looks like grey is out of stock?
Omnia1
Just updated the firmware of the Gear S2. Change Log is as follows:
I think the most significant addition from a usability standpoint is the unread notification on the watchface. You now see an orange dot at the 9 o'clock position of the watchface when there are unread notifications.
Now if only the unread indicator is shown in ambient display mode as well, that would be perfect. But as usual, all these IT engineers and designers love taking half steps ... sigh
Anarky
i think ambient mode is meant to be minimalistic.. perhaps they should add a 3rd option for the always on so we can have it off, minimal, or full-display (for the ones who are fine with 1 day batt life)
glad they're pushing out updates, though I took some time to figure out how to get into the software update screen after accidentally dismissing it
x3dnd3x
The only worry for this kind of watch is the battery. If use 1 year only then battery kong out, so not worth it. :sad:
Anarky
1 yr warranty nia.. if battery cui after 1 yr then u probably have to pay to replace.
So I've received my strap le, now i know why couldn't track, china post registered air mail in an envelope.. at least i got my goods undamaged. Still waiting for the tempered glass screen protector, tracking says it was sent to Malaysia, and re-sent to Singapore last Friday = =
flyhigh777
Hi Folks,
Can it talk and listen thru it ? I am abit confused....some said can but via bluetooth..but I watch the youtube and you can just listen and talk over it.
Omnia1
Hi Folks,
The Gear S2 has a 3G version (not in Singapore) and a non 3G version. The Gear S2 Classic only has a non 3G version.
You can make phone calls on the 3G version but I don't think you can do that on the non 3G versions. You can dial a phone number but you have to complete the call on your smartphone. The non 3G versions also do not have a built in speaker unlike the 3G version.
You can however pair a Bluetooth headset or speaker to the non 3G versions which would then allow you to listen to music etc stored on the smartwatch.
Sent from Sony SGP621 using GAGT
flyhigh777
Thanks for the reply...have decided not to get this watch.
