Gear S2
Omnia1
r there more watch faces from 3rd party or just those c/w samsung?
You can download additional third party watch faces from the Samsung Gear Apps Store.
Alternatively, you can download the Mr.Timemaker app to your watch and smartphone. This app allows you to create your own watch faces (with some constraints) or to download watch faces created by others, and there is quite a selection!
Sent from Sony SGP621 using GAGT
evq
Thanks a lot
Anarky
u can get from q10sg. not more than $20 include postage. came in 2 sets, front and back. :)
Thanks for the tip, but how come front and back? The back protector won't interfere with the heart-rate sensor on the back of the watch?
Omnia1
Why watch once in a while then alert msg from whatsapp and sms? Watch faulty?
I get quite consistent whatsapp and sms alerts on my Gear S2.
If not already done so, make sure your S2 has not lost bluetooth connection with your smartphone and that you have not disabled alerts on your watch when your smartphone is on and in use. There is such an option in the notifications section of the Gear manager app. This assumes that you want alerts on the S2 when your smartphone is is on.
galaxynote
Thanks bro..so the main comms is bluetooth between phone n watch?
mr_voodoo
amazon has the classic on sale for approximately 420 SGD
Qualifies for Free Shipping to SG
but you will incur GST
you can use other methods at your own discretion
Omnia1
Yes. If your S2 is disconnected (in standalone mode), a small watch symbol will appear at the 12 o'clock marker position of your watch face.
Having said that, the S2 also has wifi connectivity, meaning your watch can connect to your smartphone over wifi (Internet) instead of bluetooth in situations when you are out of bluetooth range from your phone. But you have to make sure that wifi has been properly set up in the watch.
marcus70
Hi any diff between local and export set,going to get one from q10,advertise as local,anyway to check eg imei or serial ?
vagus1978
Sharing a deal i found. Qoo10 has a Black Friday $50 discount off >$300 purchase. I used it to get a local set classic with local 1yr warranty.
I think is better than the Sitex deal where it is rrp and only giving extra wireless charger.
Sent from Samsung SM-G925I using GAGT
bagyidaw
Does Gear S2 support iPhone? I'm using iPhone currently and thinking of getting gear s2.
It looks different from other smart watches and rotating bezel feature is cool..
TrueB1ue
buy normal screen protected better or glass one huh?
easy to remove if paste wrongly or broken?
which brand or where to buy best huh?
toyomi
How to download mr timemaker into our gear? Frm the apps it showed installed but my gear show nothing at all, unable to install ... I tried other apps no problem, oni this mr timemaker gt problem.. TIA
Omnia1
The app comes in two parts. One part to be installed on your Gear S2 (get from the Gear store) and one part on your smartphone (get from Google playstore).
You use the smartphone app to choose your watchface which you will then send to the Gear S2. Make sure that you have chosen the Mr. Timemaker watchface on the Gear S2 to enable the link. On the Gear S2, Mr. TimeMaker does not appear as an app but as a watchface amongst your watchface selection (long tap on your watchface).
toyomi
Got it!!! Thanks alot... :)
Anarky
Just wanna share I got mine from Kasia mobile on Sunday for $465.
Staff was patient with me as I checked for scratches and if everything was in the box (probably since I'd already paid before they let me break the seal to check the contents). Satisfied with my purchase so far.
Now I've just got to tahan the wait for my strap and screen protector bought from aliexpress (12 USD total), fingers crossed they won't take 60 days to deliver.
