Lazy_Tiger
- Jun 4, 2002
I see, thanks!
How does one adjust the grind size of grinders? I just bought a macap m4 and it's the first time Im doing this making coffee from beans kinda thing. You have to turn the machine on with beans inside the hopper while adjusting the grind size? So beans will be wasted? Or do u only need to on it but not have any beans in the hopper? I only read that u can't adjust grind size with the machine off as it'll damae the grinder, am I right?
COngrats on your new grinder!. Yep. Best to adjust with the motor running but i suppose if its just tiny adjustments i guess should be ok. If the grind setting is filter coarse and if you twist the grinder to fine setting without running the grinder then may cause the grinds inside to compress and get stuck inside. happened to my rocky when i was too impatient.
