Lastwishes
- Jun 12, 2005
Also, when steaming milk, my milk gets hot way too quickly before much air can be introduced although i am dipping only most of the tip into the milk and a slight bit of the tip just above the milk.
When steaming milk how much to turn the steam knob?
Does it make any difference?
I think the usual practice is to always turn the knob all the way. Also, to get the nice wet froth, or a very foamy one, the trick is to surf the tip on the surface of the milk for a time before submerging the wand into the milk to heat it up. Depending on the strength of your boiler, the timing can vary.
I usually go with 23 seconds surfing the tip if I make a latte, and about 33 seconds for cappucinos. For the silvia, the timing should be faster. Experiment a few times and try to find the sweet spot to get the milk swirling/play with the timing.
@lazy_tiger/chikyblink:
have you guys made lattes with red brick? Don't know if I'm doing it wrong, but I had to aim for a rather long overextraction in terms of timing (about 40 secs) to get a normal tasting espresso.
The espresso I got from is pretty decent, very fruity and exciting on the tongue, and nice cocoa afternotes. Very nice to drink as an espresso.
Making a latte with it however, is somewhat weird. Still getting rather strong citrus notes, which was surprising but not unpleasant. As I'm rather used to very smooth tasting lattes (mostly after the milk, the strongest taste is usually the cocoa taste for most of the beans I've tried, with more subtlety on the fruity notes; I'm getting very strong fruity taste still with red brick), I'm not too sure if I'm doing something wrong, or its just the way the bean's supposed to taste.
I'm using a 19g dose, extraction into approximately 40ml. Didn't go with exact timing, but rather, I went bottomless and watching the striping and stopped the shot once right before the initial signs of blonding.
