thanks. was going for that. cant find much review on magister m6
Depends. Sometimes single, sometimes double.
Sent from Samsung SM-N910G using GAGT
Local grocery help me roast the below to 410F.. Maybe next time try 412F
slightly off topic but i have a problem with my rancilio silvia. Whenever i turn on the steaming function the machine seems to be conducting electricity. Whenever i touch the machine on the metal parts, i feel electricity. There definitely seems to be a problem and the electricity currents i am feeling is getting strong hence the need for me to ask y'all about this. This didn't happen when i got the machine it started after about more than half a year since i got the silvia. Anybody can help??
Not in Singapore right ?
Sounds like a loose earth wire. Maybe check the 13A plug that all the wires are secure?
its a european plug as i bought it online. The plug doesn't seem to have a screw such that i can remove the cover and see...
Is the power cable removable? Maybe try another power cable?
Unfortunately it is not. Do you think its a problem with the internal boiler or electronics inside the machine or is it definitely a wiring issue? Sorry I have absolutely no knowledge in how electrical appliances work. Because if its the internal stuff which is spoilt, I may have to send it to repair
What do you guys think of Dritan Alsela's method of steaming milk in the video below
https://www.youtube.com/watch?v=heKdbO6H86U
He places the steam wand to the side of the pitcher making the milk swirl in a circular motion instead of the more traditional "rolling" method where the steam wand is placed in the middle of the pitcher.
Ive been having a hard time steaming milk where the top about 1cm of the milk i make is more foamy than the rest of the milk in the pitcher. Like when i finish steaming and leave the pitcher to a side to wipe off the steam wand, there is a layer of foam sort of crusty like on top. I usually just swirl it to get rid of it but in latte art videos i see the milk is so shiny and smooth throughout. Any tips?
European plug's earth is on the European socket.
