(GPGT)Espresso machine hoot
Lazy_Tiger
hey guys... i'm still searching for my espresso machine. recently i heard NS oscar 2 is available. My budget is below 2 k and it fits the bill. however, the expobar seems to fit my budget as well.
need some advice please! intend to get it before new year
Do you steam milk often? or just go for espresso?
2k budget includes grinder?
Someone is selling an oscar on carousell for $1260
https://carousell.com/p/27570160
patryn33
Oscar 1 and 2 price diff like Rm$400 in Malaysia @ lighthouse coffee going for rm41xx.
But here like sgd$400 for $1600
https://carousell.com/p/36533816
Machine alone 2k or machine and grinder 2k??
Some expobar assemble in China
testerjp
Budget tight can consider Expobar Pulser with Bezzera BB005 grinder. Below $1800
http://www.finecoffeecompany.com/shop/expobar-office-pulser/
http://www.finecoffeecompany.com/shop/coffee-grinder/
Or upgrade grinder to Quamar M80E at $899.
Or upgrade machine to Expobar EB61 at $1599.
I think now have sale on Expobar, din see it last week.
Now gd coffee machines like getting so cheap, coffee bean sellers are going to get good business.
Edit:
My friend emailed the carousell guy and he says there's zero warranty and future support.
If want to take the risk, i think just order yourself from overseas directly.
compuser
There's a high concentration of scammers on carousell.
Furthermore, I dont think those are official sellers n expect long term support.
I will rather order from overseas.
compuser
If you drink Americano and long black alot, can just get a chemex.
They allow you to test various machines there, so you can have a very clear view. I personally like the Bezzera Strega the most but I already bought the Brewtus. Maybe just check with them the cleaning process.
testerjp
Ya at most, I think they just order from overseas or ebay cheap then sell, no warranty.
As well order from overseas directly yourself.
But coffee machines with no local support is damn risky.
Every few years sure have to maintain a little.
Corsabrin
Is chemex really good? it looks like a drip?!
compuser
Can't say it's better or good, it's up to your preference.
I taste before, it's lighter like tea.
It's more troublesome and may not fit your criteria though
patryn33
Chemex is drip!
Using paper filter yield cleaner taste. Higher caffeine content
Really depends on preference. I wouldn't say lighter than tea. Go into s cafe and try it and see if u enjoy the taste
I use both Chemex and HX. I enjoy latte more than Chemex.
Chemex less work than HX. No need expensive grinder, no HX to maintain. You just need a timer and a scale to be exact but u could do away if u don't have a acute taste.
It takes longer time to make a cup but with Chemex u making many cups.
Both brew methods
- time grind beans, Chemex don't need super fine
- time takes to boil water almost same as HX
- Chemex just clean with soap and water, HX needs back flush with water b4 shutting off, weekly or mthly back flush with cleaning tablets. Once a year may need to remove shower screen to clean.
testerjp
Anyone do cold brew?
Anywhere to learn?
Can i do with a hx machine?
patryn33
Anywhere to learn?
Cold brew and heat exchange? I don't think they mix
A lot of YouTube videos and stuff on line from cafe on cold brew
Ie
https://bluebottlecoffee.com/preparation-guides/cold-brew
A lot of comparison on brew techniques
https://www.thrillist.com/drink/nation/best-iced-coffee-how-to-make-iced-coffee
testerjp
Wow, 2 litres is too much.
I'm am thinking of doing just a few cups
testerjp
For either methods, do I need to adjust my grind setting coarser from espresso grind size?
Radeon
Usually for a full immersion cold brew like toddy I grind around slightly coarser than french press, and typically a medium-fine grind for dripping over ice.
Its best to experiment to taste, but definitely will be quite a fair bit coarser than grinding for espresso.
patryn33
Chemex is certainly more costly, hario v60 is a good entry to drink long blacks. Little investment.
Lazy to buy paper filter just get this Osaka
http://www.amazon.com/gp/aw/d/B019QTUZAU/ref=pd_aw_sbs_79_1?ie=UTF8&dpID=51hdf%2BhOabL&dpSrc=sims&preST=_AC_UL100_SR100%2C88_&refRID=1VEJF88BHJ3HF4XYM3VF
testerjp
Since it requires a coarse grinder and I don't do it often, I think I'm getting a small hand grinder and leave my espresso grinder alone.
What is a good grinder for such drip i can get from Amazon??
