IntelFlash
- Sep 6, 2000
How they roast at home, with what?
I don't mind roasting at home too.
Just found out the greens in SG not cheap.
Think just stick to buying from roasters.
I got 8kg each time. I roast 300gm every week.
I bought mine from a local roaster. Small startup.
Trying their blends...
How do you like their blend? I find it goes very well with milk. The cocoa flavor cuts thru the milk and is not downed out like in other espresso blends.
Is that a kraft bag?
Won't it breath oxygen in?
not bad. the sour note is very strong on first sip. will try more and see how it turns out on my machine.![]()
I think they roast base on their pressure profiling machines, so may not work well those machines with flat line pressure profiles
The version of iron bark I tried was quite dark roasted so I'm quite surprised your found it sour. Maybe they changed their roast level.
I brewed it at 92 degrees with a 50% ratio.
