BlurSotongKia
- Jun 16, 2012
Skip the flair and rok. I have use the flair side by side with the robot, work flow wise the robot wins hands down due to the lack of preheat and lesser parts..
The flair require a pot of boiling water and tongs to preheat the chamber making the process longer. The removal of puck requires some work too.
The rok is filled with plastic parts in the brew chamber, and many of it are prone to cracks leaks and failure after long use.
The robot and grinder are easily moved around due to it's size and weight, it's not contain water and does not require power. My robot machine I usually put it outside in the hall area after using it as a show piece. You can easily move it around with one hand. The only sizable thing would be the steamer which would need a dedicated space.
A good grinder will help tremendously with dialing in. The jx PRO is top dial adjustment with near stepless dial, it's specially made for espresso dialing in. Grab some fresh roasted beans and you are on your way to coffee heaven.
I can’t find a Jx pro though. Only the normal Jx. I do see a EPro. Will that be better?
Edit: I saw a Jx Plus. That should be the one I think
