(GPGT)Espresso machine hoot
compuser
$200 off the Bezzera Strega.
Else I may settle for the Bezzera BZ10 which my father owned and is still solid.
You found any vouchers or have extra vouchers to spare?
I'm looking for the Bezzera Crema or Strega too.
Lately I was in this acoustics club, one of these guys owned the Strega and I finally tested it.
The espresso produced from the same coffee taste is so much clearer and smoother than from my Double Boiler.
*Update*: It's okay, I got the Bezzera BZ10 since they have an offer. Very happy with it. :o
hardwaregone
My bezzera is still solid, the strega has less moving parts so should be much more lasting. :)
I was thinking of buying a used BZ10 or bz13 unit for my office at carousel, but the listing are all gone. Not even the E61. Last year saw quite a few used ones. :(
jayz89
is the Breville Express at $85x good buy?
looking at Dedica but need a seperate grinder which is abit ma fan leh. Cost and space wise
*EDIT
nvm i got the dedica instead lol
potato13
*EDIT
My 1st machine was a delonghi dedica too..
I would say its a good started machine, but once you get into it. you find that the extract may not be consistent enough + the steamer is not as good. And when you touch on higher end model, u realize its a machine limitation.
I always prefer a seperate grinder instead of a all in one.
Enjoy.
hardwaregone
*EDIT
Always get a separate grinder.
I think a lot of people went tru the dedica/single boiler then quickly upgrade to a better professional machine when they realised that the result is not up to what they expected. :(
Get a proper grinder in case you want to upgrade and you can still use the grinder. :o
Was about to say consider buying a used Bezzera BB005 grinder which has tanked with me for almost 10 years. Strangely, carousel now even the grinder also can't find. I clearly remember there were quite a few last year.
jayz89
I got myself a breville dose control grinder
entry lvl experience for me. Start off budget and see how haha
jkohlc2
Tried this, taste pretty good, initial notes of strawberry
Read HWZ Forum Rules!
joesph
Is Gaggia owned by Philips?
Yes, that’s right – Gaggia was purchased by Saeco in 1999; Saeco was then purchased by Dutch-based electronics manufacturer Philips in 2009 With both Saeco and Gaggia now being owned by the same company, it’s to be expected that there are a lot of similarities between the two brands.
owned by Phillips and brought in by boncafe is a no!
compuser
My extraction so far is okay, anyone using single baskets here?
My extraction is far better with a double.
I'm thinking of getting a distribution tool but not sure if it helps.
