(GPGT)Espresso machine hoot
ZacharyA
Anyone owns the DF54? My Varia VS3 gen 1 motor died after 1.5 years, so I need a new replacement.
Thinking of either the Baratza encore esp, DF54 or Niche Zero. I only make espresso and prefer to single dose.
I don’t recommend Encore ESP, compared to what you have been using and the other two options. Niche Zero is not bad if budget is not a problem
j4jersey.
currently is considering to get either a Bambino Plus or a Gaggia Classic Pro to pair with Eureka Manuale
travbug
Hi I currently own a Delonghi Dedica EC685 and looking to get my first grinder. Was reading up on the different grinders and was hoping to get some advice here.
My wants on the grinder to be purchased
- budget around $300+
- decent grinds for espressos (I only make espressos)
- easy to use (especially for noobs like me) and easy to clean/maintain
With that in mind, I'm thinking of getting either the Baratza Encore Esp (better espresso grinds) or Breville Smart Grinder Pro (better features - grind directly to the portafilter, timer). what would you suggest that i get?
potato13
I would recommend Baratza Sette 30.. if its that price range + abit..
travbug
Thanks. I went to read up and watch youtube videos on this model. The noise level is rather loud. o_O
In terms of espresso grinds, the Encore Esp seems to be better if I read correctly? more settings for espresso and a better burr?
potato13
i didnt use the encore before so hard for me to make compare.
And yes, he Baratza is quite loud.. But for espresso grind, it works.. as it can grind quite fine..
i upgraded from it to niche zero..
So far best upgrade. lol
laeticia
How is the grind from Niche Zero? I am lazy to do WDT which I didn't need to with Varia VS3.
zyklon86
My very 冷门 and old school setup. You know then you know.
ZacharyA
Bo bian.. wan good, than its among the best for consumer already..
Commercial grade will be higher cost..
I'm looking to upgrade my "lousy" Baratza Encore ESP. I don't find it any better than the Baratza Encore.
Will upgrade once I moved into my new place. Now countertop space is very very limited.
potato13
Slowly lor.. Also took me years to slowly upgrade and upgrade..
My current setup #7,267
