Sylar22
- Jan 2, 2009
This is what I used to do to get finer foam when I was using a pannarello style wand with the Jura
CoffeeGeek - Frothing for Newbies & Intermediates
Check this out about the pressurized portafilter. I suppose if use fresh beans grinded at the correct size it should still make good espresso. I suppose the capsule machines work the same way.
How a Pressurized or Enhanced Portafilter Works
Thanks for the info ! I've read up quite a bit but there's so much difference in theory and when i actually steam the milk hahaa. The steam wand really cmi -.-. Anw any suggestions for an economical grinder ? Is the delonghi KG89 any good?
