aucheukyan
- Jun 27, 2009
u nv see ur pm inbox?
burn dip dip into my mind liao.. thx
100airbrushes
I remembered last campaign there are stickers on the kit themselves although i dont know if they give the serial number card separately or included inside the kit.
ok thanks.
i shall invest all my hongbao money.
I ordered an ab + compressor set from airbrush.sg
Is there any other necessary things i need to get? What should i buy to clean after usage?
i must say ,, nice shading ... good job
ya... age, seed, and maybe unicorn...i thought is selected series only?
cleaning pot? ..can double as an ab stand also
maybe a spraybooth?
cleaning brush?
nozzle cleaner?
mini filter?
hi which set did you order?
I'm gonna get one set from him also, but that model got no stock.
ah thanks! noted.
I ordered the EAD-B81 and EAD-K381, you bro?![]()
u can see here for tutorials for spraycan
How to use spray cans to spray paint
tutorial for candy gloss
Error
hi guys, i remember a few months back a few people managed to get an iwata airbrush from hongkong/taiwan (can't remb).. will it be cheaper to get it from Japan? will there be any compatibility issues like hose too small or wrong size i dunno what..
And for those people who are planning to go, can share how much is the air tix + hotel stay? I got one sort of subsidized study/play trip to Japan for a week dunno whether it's worth it or not..
ha, if you go HK, go 通菜街 and take a walk lo, you will probably get devoured and never to leave that place again...... iwata is quite ex in HK, Procon or Sparmax are much cheaper compared to sg, iwata is around the same as sg. You can ask what is the connector size and you should be able to get the adapter if it is different in the same shop.
Assumptions made that you know cantonese and you have exp with airbrush and tanks............
just air tix on budget is around SGD250 per head, two ways. I heard that if you book those 3d2n free and easy trip is much cheaper choose those newer 3-4 stars like eaton hotel in nath
an road, my friend say its not bad, but personally i have no exp cause i have house and relatives there......![]()
