[Help] My PC cannot start
Scp173
When I press the power button,
The fan behind spins for 1 second then stops
No spooling up sounds of any kind like it's supposed to have
No beep sounds
What's the problem?
Power supply faulty
I hav this problem too, but last time i noob even bring the mb down for exchange/repair and they test it on the spot no issue but i bring back fix back still same, tat how i conclude i hav a bad power supply
york
Can try a skeleton boot of the mobo....that mean... minimum device....only a stick of ram, processor and use the on board video-out if there is.
Elvin_Chong
Some PC the CMOS battery drained already cannot start. I experienced this on a few PCs already. I dunno why also.
PikaPika33
High Honorary Member
cmos battery
psu
ram
wire loose
some of the more common issue to test first
gregory_choo
me t
me too.
i experienced several times. first time didnt know, bought new mb to replace.
now this is the first thing i check.
after putting in the new battery, do a clear cmos operation first.
tomsss
check ram
check gpu
check cpu
check psu
last would be the mobo
that's why i always got a spare of all the listed parts above for testing.... except the mobo 😬
ridiculous?
mine laptops turn on the socket doesnt even responds.
neh change anytings.
second one to die using same sockets
:o
coyote
No beep sounds
What's the problem?
Can be motherboard or power supply issue.
rarenick
Normally when desperate I will clear cmos or change battery. If cannot work, I will reseat the components one by one with the minimum items plugged in, meaning the USB devices disconnected, except mouse n keyboard.
Read HWZ Forum Rules!
Unic0rn
bring to sim lim shopping mall for the pc shop to check!
KnyghtRyder
No beep sounds
What's the problem?
Either power supply or motherboard.
