[Help] My PC cannot start
dambio
Worst is teeki dun bring to profesionals to diagnose. Scare to spend or scare tio pian is another.
Not everyone's neighborhood has a pc repair shop. Or car can just drive to sim lim lor.
Actually can ownself service also can la
Psychedelic Senses
you always post hantu YT videos here. now hantu messing around with your PC, don't allow u turn it on liao
uselessbum
Paperclip jumper poweron btw is meaningless if you have no multimeter to check the rail voltage.
A 12V PC fan can be a crude substitute if you are familiar with how it normally performs.
I suggested it is because it is a quick and superficial (ie dummyproof) way to determine if the PSU "works". If it doesn't even spin, then it would greatly increase the likelihood of the PSU being the issue and would be grounds for an immediate RMA. That's why PSU manufacturers like the one I linked suggested it.
Of course, even if it does spin, then it doesn't necessarily mean that it isn't at fault either but it would at least warrant further investigation of other components first.
Tony.Manero
What do you mean
I just plugged in the old spare PSU into the motherboard
Turned on the PSU power and pressed start button
Same symptoms
Cannot start up
I see the processor fan spin awhile then stop
Means this old PSU can provide power to motherboard
So obviously my original PSU is not spoilt or the problem
What is the next step?
iu
Take a look at this pic. There's ATX power connector and 12 volts connector ( top right). Both power the motherboard
gregory_choo
remove ram, graphic card, hdd from mb. put in new cmos battery, reset cmos. turn on power, should hear error beep or see error code due to lack of ram, hdd..etc
if nothing, then change mb.
Hot_Dog
probably chiur pi sai stuck on the mobo, bridging some of z contacts. go clean out the mobo, new thermal paste and reseat cpu and try again.
orpisia
Emeritus Honorary Member
Before considering changing parts, start with something simple.
Make sure the power cord to your PSU is tight. Some times you may accidentally shift your computer a bit and that could result in your psu power cord losing contact. Make sure the power cord is in fully and use your hand to hold it in place in a centre position then try switching on your PC again.
If you computer does switch on, then it means that your power cable is loose and you need to find one that can fit snugly into your PSU so that it doesn't droop to one side. Alternatively, you can use cable tie or something to hold it in place/prop it up.
If you want to test PSU, then do the "paper clip test", look at the following link. But that one got to take out the atx 24 pin which can be hard to do. Make sure eco mode is off as well othewise psu fan might not spin.
https://help.corsair.com/hc/en-us/articles/360025085372-How-to-Test-a-PSU-Power-Supply-Unit
I tried with spare power cord also same thing
uselessbum
Does your motherboard have RGB lighting on it?
When computer is assembled, with the atx 24 pin connected to the motherboard and PSU on, is the motherboard RGB lighting on? If it is, then it could indicate a motherboard issue.
articland05
TS can give a summary what have you tried so far? change PSU, change power cable etc...what else?
orpisia
CMOS battery where to buy
Try cheap things to fix first try
uselessbum
CMOS confirm not the issue here. Even if CMOS bat were dead, you would still be able to post. CMOS bat die, at most your bios settings won't be saved and got to change every time you shut down and on again. CMOS is just to save your BIOS settings when your PSU is off. Even if no CMOS bat, I also can on my pc, just that all my bios settings (date, time, xmp, etc) will be lost.
elbib00
How many ssd do you have? If 2, plug out the spare one and try rebooting.
