[Help] My PC cannot start
5adisticD3vil
sound like psu issue
you got spare psu but cannot connect to current mobo?
google and see if you can find some sort of adapter bah
coyote
Get this from Malaysia and send to a friend with a Malaysia address...
https://shp.ee/r7su6f8
impossible to get them at such price in Singapore. Not to mention, it's Gigabyte motherboard, best of the best in reliability!👍
hardindex
ensure ur mobo connectors are not loose.
take ram out and use eraser to rub the contacts (dont underestimate this step, it save me from a lot of weird PC issues)
psu are very sturdy so i wouldn't assume is psu yet...it is also one of the hardest to troubleshoot
PSU are the worst, even branded one
orpisia
Emeritus Honorary Member
Sound like psu uplorry
Read HWZ Forum Rules!
psu problem.
Sounds like power supply issue.
Once change PSU, whole PC can work again.
Try unplugging your RAM and inserting them back again.
Disassemble and remove psu from pc and do paperclip test
too much dust clog the fan? :frown:
PSU is the main component that fails now that hard disks are no longer a thing.
Borrow one to swap out and see if it fixes things.
Take out component blow big big for awhile, then put back
Too dusty
change the cmos battery
try the cmos battery first. good advice.
Cnos battery drained Liao, still can boot up one
ram issue.
You pray that it's your psu and not Mobo issue. Mobo issue are the worst thing that can happen to you, the most difficult to troubleshoot
cmos battery died, the mobo will still go to the setting for a re-step up.
yes, the mobo will go the bios setup display.
Likely it is the mobo circuit go hay-wire liao. the PSU detected it and auto cut-off to prevent further serious damages to other components (if it's a 80+ psu)
Power supply faulty
I hav this problem too, but last time i noob even bring the mb down for exchange/repair and they test it on the spot no issue but i bring back fix back still same, tat how i conclude i hav a bad power supply
psu or mobo
better bring it to a pc shop
Test PSU first then slowly check others if failure again.
Some PC the CMOS battery drained already cannot start. I experienced this on a few PCs already. I dunno why also.
cmos battery
psu
ram
wire loose
some of the more common issue to test first
80 % is psu issue.
buy a cheapo psu to swap over and test.
me t
me too.
i experienced several times. first time didnt know, bought new mb to replace.
now this is the first thing i check.
after putting in the new battery, do a clear cmos operation first.
motherboard up lorry liao..
Should be psu
check ram
check gpu
check cpu
check psu
last would be the mobo
that's why i always got a spare of all the listed parts above for testing.... except the mobo 😬
Can be motherboard or power supply issue.
Normally when desperate I will clear cmos or change battery. If cannot work, I will reseat the components one by one with the minimum items plugged in, meaning the USB devices disconnected, except mouse n keyboard.
Too much dust insai neber clean? :LOL:
Either power supply or motherboard.
D worst is dunno which part is faulty
Yo people
I got 1 old, spare PSU
Although its power connector(which is supposed to connect to the motherboard power connector) is different size(it is smaller), but I still can plug it into the motherboard power connector
Turned on the power
Guess what
The processor fan spinned for few seconds then stop
Means this old spare PSU can provide power to the motherboard
Can rule out the PSU hor?
Think the original PSU is not spoilt
What the next step?
coyote
Yo people
Turned on the power
Guess what
Same symptoms
Refer to post #42.
Tony.Manero
Yo people
Turned on the power
Guess what
Same symptoms
Most mb now requires 2 cables into mb. Your old one has?
orpisia
What do you mean
I just plugged in the old spare PSU into the motherboard
Turned on the PSU power and pressed start button
Same symptoms
Cannot start up
I see the processor fan spin awhile then stop
Means this old PSU can provide power to motherboard
So obviously my original PSU is not spoilt or the problem
What is the next step?
tidiii
Yo people
Turned on the power
Guess what
Same symptoms
yo
guess what
if not psu spoil then u good luck, is probably mobo.......
anyway like i said, best to bring down to a shop and check
DragonFire
Zippy Emacs server PSUs last forever. The machine I built with one is still running after 12 years of almost 24x7 Meanwhile my top of the line Corsairs on my main machine become paperweights every 3-5 years or so.
DragonFire
What do you mean
Same symptoms
Cannot start up
Your old PSU confirm working? Got multimeter?
Jumper the power on leads (google ATX force power on) and check the voltage rails when powering up a 12v fan.
It is looking less like PSU and more like motherboard now. If you can, remove everything except RAM and CPU. Blow out all the dust and check the capacitor for bloat,
Reseat all the power connectors and RAM and power on. Look for error LEDs or listen for beeps.
Nothing? Try only 1 stick of RAM.
Nothing? Try the other stick of RAM.
Nothing? Try a different RAM slot.
Nothing? Reseat CPU - you will need thermal paste.
Nothing? Borrow one more PSU - old PSUs do fail on the shelf for some reason especially if heavily used. I blame the dust collecting moisture that corrodes internals.
Nothing? WLWLSMDWL. Time for a new motherboard.
uselessbum
Before considering changing parts, start with something simple.
Make sure the power cord to your PSU is tight. Some times you may accidentally shift your computer a bit and that could result in your psu power cord losing contact. Make sure the power cord is in fully and use your hand to hold it in place in a centre position then try switching on your PC again.
If you computer does switch on, then it means that your power cable is loose and you need to find one that can fit snugly into your PSU so that it doesn't droop to one side. Alternatively, you can use cable tie or something to hold it in place/prop it up.
If you want to test PSU, then do the "paper clip test", look at the following link. But that one got to take out the atx 24 pin which can be hard to do. Make sure eco mode is off as well othewise psu fan might not spin.
https://help.corsair.com/hc/en-us/articles/360025085372-How-to-Test-a-PSU-Power-Supply-Unit
kuti-kuti
When I press the power button,
The fan behind spins for 1 second then stops
No spooling up sounds of any kind like it's supposed to have
No beep sounds
What's the problem?
maybe your pc power button got problem
junjie433
What do you mean
Same symptoms
Cannot start up
Previously chiu never change anything right? If PSU is fine then high chance is the motherboard problem.
Hot_Dog
Sometimes mobo too dusty also can like tat huan. Just take some alcohol and gib chiur mobo a wipe see how.
pigpigoink
unplug plug ram, harddisk and try again.
one possible reason ish motherboard going gg.
DragonFire
Tiagong from Unker google that many modern consumer boards do not come with onboard buzzer. Maybe there is a beep code but just that it can't be heard.
DragonFire
Paperclip jumper poweron btw is meaningless if you have no multimeter to check the rail voltage.
A 12V PC fan can be a crude substitute if you are familiar with how it normally performs.
