Help to view the spec
kurui_
The rig u are currently considering to buy has history behind it. The HWZer by the username of "ProGamer84" asked for opinions on his proposed rig by spamming new threads here in HWC for close to a month, many HWZers advise him how to, he ignore them. In the end build rig and not satisfied, come back here to try to justify his purchases. Got shot down by the very people he ignored for advice, he created a scene here and got himself temporarily banned. Now u r about to consider buying the very rig he is trying to offload at a minimal loss (he bought all these first-hand at $2980 about a week ago, so trying to get away with $130 loss). So opinion is quite strong here. Many here do not want u to bite his bait coz they know how bad the rig is (some even initally thought u were his clone trying to come back to sway opinions). Just go a search on his username using the HWZ search function and u will understanding where this came from and where this is headed.
He is trying to sell away his "mistakes". So... ya. Guess people just trying to warn ts about it.
But than again;
Your rig, your choice. Period.
Jenny170
weather what is post here and there. Is not my problem after all. He got wat history also none of my business. But what i check the rig, so far the outlook from the pics he send me look nice thot. If is rig really buy ard that corner and no problem why not i give a try. So right now i asking for some tips here to check is worth to buy or not. And i do believe that our bros here given me a options right now. So right now i just consider. Of cos i will go sls tmr again to check the prices again in others shop.
PS: God Teach us to learn to forgive an forget. Not created hate.
Imho,
Mobo:
-If you want rgb don't go for the tuf series. Can go for Maximus or strix instead for Asus. There are lots of other mobos in the market too.
-If you really want the 5 years warranty of tuf series get the mark 2, unless you must have the mobo shield.
Rams:
- you'll be better off getting the new g skill rgb rams corbell are bringing in (which are arriving) than those the seller is selling.
Case:
- corsair 570x right side panel is tempered glass, it will look really ugly if the cable management is not in tip top condition.
CPU:
- can get an i7 7700k instead of an i6 7600k with your budget.
Psu:
- as the other forum-ers said, thermaltake probably don't cut.
Gpu:
- if you really like the gigabyte g1 extreme, you can buy it also.
- Else you can shop around for one that suit your taste.
On nzxt Hue+:
- It'll be better for you to check if Asus aura and hue+ got any conflict or not and if it syncs.
-is nue+ actually even needed when you already have aura to control fans rgb. Since you'll already need Asus aura to control your Asus mobo rgb.
Final words:
-Why compromise when you can customize one that is to your taste yourself with your own choice and decisions at the same price?
-If you really like his build than just go for it, but please don't buy an i7 7700k to replace the i6 7600k.. it's sort of counter productive, (imho) no one will buy a used i6 7600k at brand new in box value..
But than again;
Right now i was thinking going for the gigabyte the Rgb of the mobo look nice... Anyway thanks bro for the info and comments.
lalalalalala
Jenny is pg84 la. Can tells froms the English's thot.
Anyway if jenny is really not PG then don't buy the rig, because buy liao you will want to sell it and change the mobo to a Asus strix
Sent from OnePlus A0001 using GAGT
MianBaoFren
Jenny is pg84 la. Can tells froms the English's.
One thing I don't understand is someone already did a price breakdown of a somewhat similar rig and is much cheaper. There's no reason why anyone who is profit seeking would harp on it further unless...
And I don't see how that ssd thrown in is worth 300ish
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
lalalalalala
kurui_
Think I'll use the money to get a maximus code or hero. A little more only can get maximus liao, don't understand why get a TUF mark 1.
Here's the thread for the g.skill trident z ram ts:
http://forums.hardwarezone.com.sg/h...eries-unadulterated-rgb-illumi-5529282-7.html
Jenny170
Jenny170
most to most, im looking for QC and warranty that it. yes Maximus code or hero are close place to Tuf about $100 plus. But with 3yrs warranty, 2nd which i dont OC anything. So is wasted right?
kurui_
imho,
1) If you really want the 5 year warranty, get the mark 2. It will not look nice in a rgb build though (same for mark 1).
2) If you don't OC, any z boards like the z270 be a waste of money. Minus perhaps mark 2 for 2 more year of warranty if you really want it.
Jenny170
Honest advice PG, sell your rig at 2k, might have pple eat. Or sell at 1k and keep the GPU.
Then get urself a new rig with a non k i7 & a basic mobo since you not going to oc.
My own rig mobo die, and using 5th gen cpu. gpu is 780ti. those gpu and cpu my frd wanna to buy. so at the being time i using my laptop for gaming abit. Tmr i heading to SLS again to get quotation and check all the prices...
Jenny170
imho,
im looing forward for the gigabyte z270x gaming 7:s13::s13::s13:
ethan89
The carousel listing TS is referring to is hmmmm... very very interesting :s13::s22:
Hi, I am selling off my gaming rig the following setup and spec list below.
i5-7600k Kaby Lake
Mobo Asus TUF Z270 Mark 1 (5yrs warranty)
Deepcool Captain 240EX AIO water cooler
GPU Gigabyte GTX 1080 8gb Extreme Version (4years warranty)
Corsair Vengeance LPX RED LED 16gb 3200mhz
fans x6 Cosair SP120 RGB With remote
Nzxt Hue+ Rgb led light 4 strap
Thermaltake 630W PSU
Corsair crystal full tempered glass 570x
Window 10 64 bit software key
this build cost me nearly $2900. I selling off at $2850/FIX.. All the box and receipt will given to prove for the warranty. all less then a mth. as u know new gen mobo and cpu just came out last week... For keen buyer pls come to my house to test and view. Taman Jurong...
RTS: I wanna to build a new system with sync up with NZXT RGB light, as well Aura RGB.
PS: Dont pm me talk to me rubbish. Got money just buy no money pls FO from my post. HWZ alot of kids doggy like to be troll and useless no balls kids.
https://sg.carousell.com/p/wts-my-powerful-gaming-rig-84997924/?ref=profile&ref_referrer=%2Fkrystal2015%2F&ref_sId=5246517
Jenny170
Dear admin, i will like to close the thread if can.
PS: Thanks for those bros who really used ur heart to give me suggestions. And of cos i will look into ur advice and seek for prices in sls tmr..
