Help to view the spec
Holee17
Ahahaha this really sounds like PG84 :s22: hi hi hi smurfer
power to the max!!! YOU are the best criticism on others which are totally Different person..
Like what i say early. Im going to nego the price with him till 2.5k...
Joker.. if u dw to OC why keep on saying need to get the motherboard and CPU?
most to most, im looking for QC and warranty that it. yes Maximus code or hero are close place to Tuf about $100 plus. But with 3yrs warranty, 2nd which i dont OC anything. So is wasted right?
Holee17
What 5th gen are u using? Do u know that 5th gen cpu are mainly server quality cpu? And yet u want to get someone's rig with a i5 chip :s22:
I'll be at SLS today, hopefully hear you enquiring about your rig :D
My own rig mobo die, and using 5th gen cpu. gpu is 780ti. those gpu and cpu my frd wanna to buy. so at the being time i using my laptop for gaming abit. Tmr i heading to SLS again to get quotation and check all the prices...
shadow84
Since im free, decided to help u make a better decision.
This is the specs that krystal2015/progamer84 has posted in carousell:
Selling: $2850
i5-7600k Kaby Lake
Mobo Asus TUF Z270 Mark 1 (5yrs warranty)
Deepcool Captain 240EX AIO water cooler
GPU Gigabyte GTX 1080 8gb Extreme Version (4years warranty)
Corsair Vengeance LPX RED LED 16gb 3200mhz
fans x6 Cosair SP120 RGB With remote
Nzxt Hue+ Rgb led light 4 strap
Thermaltake 630W PSU
Corsair crystal full tempered glass 570x
Window 10 64 bit software key
I had came up with my own calculations based on all parts purchased online, and from discounts. Note that i did not include credit cards rebates which will push prices down. Also, this is based on you using multiple qoo10/lazada accounts.
Just for comparison should i use my cc rebates.
Your choice.
***Edited a bit coz i used the wrong total value for corsair rgb fans. Had used the discount instead of selling price.
shadow84
Note that there is no ssd/hdd included which will cost at least $250 onwards for a 500gb ssd/1tb hdd.
kurui_
Your choice.
Doraemon have corsair 570x for $265 plus option of home delivery $20 upwards. Still won't recommend the 570x personally.
I think he have some cable mods of probably $50.
shadow84
This is based on krystal2015 buying from SLS directly. As such, i wun use doraemon pricing. Most of the items stated are about the same as SLS.
kurui_
If one wants to get the exact same build as his, they can follow my excel. but we wun recommend as it is too unbalanced.
I'm sorry for being ignorant, I'm curious what is it you guys mean by being unbalanced?
Something like gpu and psu too expensive, while getting a cheap and not too reliable psu? (which is very important in a system as it affects all components)?
Koenig168
Basically, within a certain budget, the monies should be allocated proportionally. So high-end CPU should be matched with high-end GPU, PSU etc.
The most obvious example of an unbalanced component in this case is the PSU. Never mix a low-end PSU into a mid-tier rig as a bad PSU can take out the more expensive components.
kurui_
Ohh Okok. Thanks for clarifying. :)
Ark Law
Dear admin, i will like to close the thread if can.
PS: Thanks for those bros who really used ur heart to give me suggestions. And of cos i will look into ur advice and seek for prices in sls tmr..
Not so fast ProGamer born in 1984. No need to pretend anymore. I have an appreciation post for you below :):):)
Then how come you selling a working motherboard leh? http://forums.hardwarezone.com.sg/c...tuf-z270-mark-1-plus-cpu-windows-5549009.html
So sad that your Asus TOUGH motherboard so fast die hor?
I can sense the bond between you and HWC, just like how your Windows key is bonded to the motherboard. Just like how you're bonded with the spirit to go around getting people to justify your glorious & masterful $2.9k system
Yes he told me all the receipts he got prove that he spend almost the cost. Plus the system build at SLS shop at lvl 5
HAHA.. I am still trying to nego with him. But however i see his carousel feedback all very strongs... None negative feedback....
Jenny170;105930835[COLOR=Red said:
]yup this is what is told me. But overall his spec highend right?[/COLOR] Cos i looking for long term usage. So The mobo i had checked all of current brand is just cover up with 3yrs. And gpu also 4yrs. review on the gtx was a better base clock speed.
But I guess everyone deserves a chance right? I guess not when you are AGAIN trying to justify your purchase, trumpeting your own carouhell account, and seeking opinions here that your system is highend because it cost a lot. Very tasteful behaviour indeed. Below is a token of my appreciation, I'm sure you'll value the effort I had put into it;
shadow84
Perhaps i should post my findings and calculations in his carousell listing?
joshuaho
Best post of the day :s12:
kurui_
Sigh...
Dear Progammer..
If want valuation of parts or ask for advice to what parts to change to can just ask nicely. Think people still will help. (With a pinch of poking fun due to your previous melt down)
No need to make new account...
Koenig168
If I can give your post more than 1 "Like", I would. :) Really pathetic of Jenny170 and his various clones. :s13::s13::s13:
