Honor 8x, 8x max
SibehHL
8x max anyone install google successfully?
think which to get coz 5000mah vs 3750 mah
got use to Mi Max 2 liao,so lasting battery is must sia :D
Received my 8x max this week. Downloaded gmsinstaller from external sources. All Google apps are working well.
The phone looks and feels good ... My only regret is, not waiting for the 6GB + 64GB to be released before pulling the trigger
But seriously, for a S$300 (RMB1499) phone... is no horse run.
Simpleonly2
Envy man..
The max come w dual band wifi?
Im waiting for red 6gb to release.
So far red on got 4gb.
garychengjw
Honor 8X user reported in!
Anyone find the colour display looks very boosted?
Sent from Huawei Honor 8X ~Blue~ using GAGT
SibehHL
Envy man..
Yep, dual band 2.4GHz & 5.0GHz since it is running on SD636
Good thing is almost all the preinstalled bloatware can be uninstalled
Simpleonly2
Great great!
Waiting for the red 6gb to be out..
Just hope my X2 can tahan till then... Lol
Ender
Check with you for the 8x Max, does the sdcard has a dedicated slot or does it shared with sim2?
SibehHL
2xSIM card slot + 1xSD card slot... total 3card slots. Same like the Xiaomi A2 Lite
Ender
Thanks for the info. I may go for the china version so to get the uncrippled version of 8X.
Another query, for china version, is it we just install the google installer, then can use a per normal android phone?
AcquiT
Hows ur 8x?
I got the set abit problem
Screen either not responsive or it always advance to few steps ahead and literally see the app run itself and clicked itself
Wana file to return liao sian
AcquiT
I bought 8x but tink kana lemon
Local Honor from Lazada
Asking them how sia..video all the issue liao
rfary
Dual 3g calls?
Can confirm the 8x and/or 8x max has dual 3g calls standby or the second is 2g only?
chrisyeo
Vibration issue
Can anyone try to play music at it highest volume and check any vibration from vibration motor ?
Mine vibrate when speaker at above 75% voulmn. Is it normal ?
garychengjw
Hows ur 8x?
No issue with screen response.
SibehHL
The Google Apps on my 8x Max has been running well so far after installing the GMSinstaller. But read somewhere that Grab apps may not run well, I didn't have that issue.
If buying the 8x, please double confirm that it runs on both wifi bands, even if China versions.
Another thing is, my phone is bought in China so the Huawei ID location is set to CHINA and can't be changed, you will require a Chinese phone number to complete the set up.
Simpleonly2
Hi, what is the setup for?
What will happen, If dun have China number?
