Honor 8x, 8x max
Ender
At Hong Kong now , shops are selling 8x max at 2080 HKD!
The sets here are not the same as the crappy version in sg?
8x for 2300 hkd
8x more expensive than 8x max? Is the HK version the China version or Global versions?
ccmheoa
Yes coz specs wise 8x has better camera and CPU, not the crappy 636 used by 8x max and mi max 3 . Only con is the smaller display. Not sure which version though.
AcquiT
Wah..
Lucky it local warranty set.
ya heng sia
but okay la,overall my cost cheap lol
$348-$12 citi-$26.88 rebate - $sd card cost
warranty + google all setup
better than TB 1399 cost liao coz also 128gb one
overall quite like the phone and it's light too
SibehHL
https://m.vmall.com/product/10086211608259.html
Is this MAX same as 8x max?
It seem to fall under huawei 9 series base on the grouping of the ads.
Very blur man.. Lol
Looks the same but probably a upgraded (deluxe) version. See the processor listed as SD660.
But personally dislike the leather back cover; sweaty hands makes the leather dirty and stinky and putting a back cover on the leather is like huh??:(
Still prefer the ordinary 6GB+64G SD660 version :D
Simpleonly2
Agreed.
Think it under huawei brand instead of honor. So they might launch that Huawei max as international version n not launch 8x max in sin
SibehHL
Downloaded SGX Mobile app on my 8x max, but can't open.
Anyone here face the same issue?
kyleongwl
I do not thinkn8x max will be release in SG...
Honor Note 10, the Mi Max 3 comeptitor also no show.
I believe Huawei will release Mate20X..(more exp) and target gamers..
focus1974
May I know the camera is better than pocophone F1? TQ
Most reviews says Mi Max 3 rear camera setup wins 8x Max flat out and the battery and lcd panel is better than 8x max..
The 8x max wins in terms of design and asthetics.
kyleongwl
That bad meh...
I'm thinking of honor 8x or xiaomi note 6 pro
(To play pokemon....large batt)
Note 6 pro = mi max 3 (and i had the expoer set 6gb/128)
The camera and look is bonus
kyleongwl
https://youtu.be/8IBz5bj7M4c
Honor 8x vs Honor Play....
Less than s$100 difference...but is it worth paying less?
kyleongwl
Took the plunge...
Another mid ranger in ny list
Very ipxsmax ish...
Rear Camera (esp AI on), is like "beauty mode on:
(Sometimes works well...sometime too much)
