Honor Magic V5
chari-men
Anyone tried AI Translate functions ?
Yup you can do one time translation or conversational direct translation on the spot.. for example u go Japan the japanese person can speak japanese then immediately translate to english for you.. u speak english they will automatically translate to japanese in voice to him..
keithlim
Yes, Honor has its own charging protocol. Any charging (wireless, wired, powerbank) need to support that protocol to get max charging speed.
nuscape
another bug when using desktop mode. My device screen is set to auto off in 30 secs, if not using desktop mode, I can just unlock using fingerprint scanner (just rest the finger, without pressing). However when using desktop mode, I rest my finger and nothing happen. I must press the buton then the screen will on. Basically While in desktop mode, resting finger will not wake the screen and unlock it. But it works when screen is on and when doing authorisation for banking/ apps, etc.. but this is because screen is on already.
Read HWZ Forum Rules!
chari-men
Yup... If you are using both at the same time you can temporarily set your screen to never turn off if you multitask.. if just using desktop mode continuously your screen will turn off and you need to press the power button to on the screen back..if both desktop mode and screen both idle you need FP to unlock it again.. how does Samsung dex work??
nuscape
Samsung Dex can just rest your finger without pressing, no diff while in Dex or not.
Tuakong
My ugreen Gan 100w charger also charge the V5 very fast.
I was surprised actually
keithlim
if during normal mode resting finger works and during desktop mode is not then it is definitely a bug.
unless honor provides a set of different settings for desktop mode, unfortunately is not.
May not be a bug, but definitely UX inconsistency = bad design.
Won't bother me too much ... just change your habit to press all the time for both cases lor
