i have dell venue 8 pro and notice that using otg cable quickly drains the battery, is this also happen in hp stream 7?
Need to observe more.
Currently, use of OTG cable for USB flash drive and Ethernet are all very short period of time (ave 10 min)
It's a 7 inch touch-screen Windows laptop minus keyboardHi guys, I'm one of the you now. Poisoned by the black Friday price but don't really know how to use a windows tablet.
Any cool stuffs we can do with it?
Is it like a normal laptop where I can install chrome and all?
Thanks!
Thanks!
I ordered this under USD6 microUSB HUB from ebay.
Suppose to be able to charge your USB devices.
Downside is can only
1) Charge USB devices and USB OTG at the same time
2) Cannot Charge both Tablet and USB devices at the same time
3) But got option to charge either USD Devices or Tablet.
Apparently the design of USB OTG does not allow you to charge Tablet and USB devices with USD OTG at the same time.
can use usb devices and charge tablet at same time?
He already said...
"Apparently the design of USB OTG does not allow you to charge Tablet and USB devices with USB OTG at the same time."
hmm i understood it as, you cannot charge both USB and tablet at the same time?
I'm asking if i can use the usb devices while charging the tablet? but ok i think i get what you mean, seems like cannot because need to power the USB devices to use them in the first place
paiseh![]()
Is there a setting somewhere to auto-show and auto-hide the keyboard, when texting if required or done?
Quite irritating and cumbersome to be manual on it.
It is a design of the micro usb and the OTG in such a way that you can either read using the OTG or charge the tablet but you can't do both at the same time...to be able to do that is through hacking or modding the tablet...
Hi guys
just to check if the window logo soft key is active? Can press the soft key will bring you to the home screen?
Yes and Yes
