Huawei Mate 10
watzup_ken
Why do u need LG to hv this feature? You just need to add/change a line in build.prop to have this enabled (this need root tho). So it is up to Huawei if they want to give you this feature,since it's already there but not implemented in the UI.
There are pros and cons with the double tap on the screen. I personally liked it when I was using a G4 back then. However to implement this feature, the screen needs to be somewhat in an active state to sense the double tap. As a result, there is an impact to battery life.
The best will be to have the finger print reader in the front, so no need for all these gimmicky methods to switch on the screen. But with all the phone makers in a race to increase screen to body size ratio, unless someone manages to have a breakthrough integrating the finger print reader into the screen itself, the rear reader is likely the way forward in the near future.
muddle
Everyone will implement front face recognition methods on their phones moving forward. Flood illuminators will be the next big thing after fingerprint sensors.
deckcard
Many thanks to LG being the first with KNOCKON that got caught on by majority of the phone makers having double tap to wake (dttw). Technology has also advance rapidly that the power needed for screen standby is insignificant. For instance, OnePlus 5 has dttw but also has one of the best battery life. Pixel 2/XL uses ambient display with double tap to unlock screen has also really good battery life. Samsung has their always on display AOD that can install an app with icon to be used to wake screen. I haven't got a chance to play with the mate 10 pro but with AOD, it may have some double tap to wake screen feature (maybe someone with m10 pro can comment) especially with new notifications.
Yeah I do prefer the front sensor but with the trend towards bezel less display right now, we have to live with fingerprint sensor moved to the back or use the face recognition which ipX and op5t is pushing right now. Let's hope fingerprint embedded into display can happen soon but I doubt S9 will have it based on what I've read.
OutBreak
FYI, LG did not invented "double-tap-to-wake". LG "claimed" that they invented it doesn't mean its true.. they only copy & paste from Nokia.
lallang67
just got some tips from the thread here.
so, would like to share some apps which i had been using.
since 2014, i had been using the oppo find 7a.
it does have double tap to wake and sleep. very handy especially if do not want to press the hard button.
i am using the SCREEN OFF AND LOCK apps to lock and off the screen.
this is free apps.
for normal launcher, you can set the apps on the status bar and pull down and activate it to lock.
for nova launcher, you can set to double tap to lock under the "gestures & inputs".
for this mate 10, not sure how to use the thumb scanner to unlock the screen ?
i have setup scanning correctly, but whenever i scan my thumb, it always go to pin number screen instead of unlock and enter the phone.
lallang67
Hi. I am new to the Huawei family. Just bought a Mate 10 pro. It's a great phone. The only issue I have is no notifications at lock screen (black screen). When I receive yahoo mail, Gmail or whatsapp, I don't get notifications except for vibration and led lights. Doesn't the Mate 10 pro have the respective app icons at lock screen?
used to use the "NOLED" apps.
now still using it. it is free apps.
you need to set the apps that you want to monitor.
example when whatapps message is in, it will flash the icon on the screen until you read the message.
knave
this is free apps.
Screen off and lock no longer works since Marshmallow or Nougat. It will go to pin screen automatically. Was like that for my Note 5 and S7E before. This is due to Android changes. Thus you have Nova launcher using a 'delay' off to so call off the screen. But I often accidentally trigger the screen again before I can place the phone in my pocket... so it can be hit and misd
deckcard
Who cares as that is not even an Android phone. You didn't see Nokia sue LG over that right? As Nokia didnt patent that gesture
deckcard
this is free apps.
It is becos you are using a 3rd party app to lock screen and Android security has disabled direct widget unlock since lollipop iirc
Stock Huawei launcher has a widget to lock screen that won't trigger the pin/pattern but it only works on stock launcher so if you use 3rd party launcher like Nova, you should use the timeout method as that adhere to Android security feature and won't get pin/pattern when unlock. It works on most situation as screen is put into a soft sleep mode but can get easily interrupted if you touch it.
OutBreak
Whatever grandpa.. Nobody cares about LG here.. you can thanks LG all you want with their Knock-Off.
watzup_ken
While that is true, I believe it was LG that made the concept popular. Nokia in their late "smart phone" offering did not really gain a lot of popularity since people are flocking to iOS and Android devices then.
watzup_ken
I suspect they would have removed it because of the implementation of finger print readers then. Considering that a single press of the finger print reader/ home button, and you can get the phone to wake up and complete the security check, it will make no sense for double tap to wake and separately input passcode/ pattern.
deckcard
I rest my case of you sounding like a kid with the countless name calling and negativity. I'll let you win kiddo.. move on...
cscs3
Before LG introduce that, there is already Andiord application doing that function. What LG do is make that as part of Andriod services. Otherwise, you will see LG patented this feature.
deckcard
http://mengnews.joins.com/view.aspx?aid=2990217
Anyway, it's already out of topics so don't hv to keep digging into something so trivial.. as long as dttw is available on majority of the phones, it's good for users.. enough said
Jacqueline.
my mate10 pro default app crashes instantly the moment i switched it on, anyone facing the same problem?
progene
Yes.. I use to have this app (Noled) as well. My 1st android phone. Galaxy S.
Now Install this to my in laws phone as their phone does not have LED.
Sent from HUAWEI ALP-L29 using GAGT
progene
Well. Back to the dttw. Finally gotten used to it from LG V10..
Use to lock my phone
If need to unlock, just pickup phone and phone auto unlock as thumb is already auto place at fingerprint sensor....
