Huawei Mate 10
OutBreak
Using mate 10 but feel lcd color is washed out compare to my 6p. Mate 10 still a good phone though. Excellent batt life only don't like the screen color.
I don't feel it looks wash out. Are you using normal or vivid mode? It looks better than my G4 and brighter. So I have no complaints.. AMOLED screen will always be more saturated than IPS screen.
watzup_ken
Can't compare an AMOLED with an IPS screen. AMOLED will always provide more saturated colours. But the colour can be so saturated it looks unreal. Usually IPS is more accurate with it comes to colour reproduction when calibrated well. I believe Mate 10's screen is very decent when it comes to accuracy of colour. Just need to get used to it.
Nevereatrice
Amoled with high resolution will burn alot of battery.
Its a trade off. Im satisfied with mate 10 pro battery life
watzup_ken
The trick to conserve battery with AMOLED is to try and use dark/ black themes. If the theme/ wallpaper is black, the leds in those areas will all power down.
watzup_ken
where to buy cheap spare huawei charger plug adapter?
Maybe you want to first define what your cheap means? How much is cheap?
I don't recommend really cheap chargers cause the build quality is really bad and not worth the hazard. You can look our for Aukey or 2 other cheaper brands, Choetech or U Green. I have been using a Choetech type C charger for quite some time and it seems pretty decent.
gt_5454
Hi guys, is there a music equaliser setting in the mate 10?
Paired with my car stereo via bluetooth but wanted a bit more bass but cant find anywhere to set it
HuatKway
Don't think there is when u use Bluetooth. Also I usually adjust in my music app. The default sound adjustment is disabled if u connect using Bluetooth
jiayelim
Sorry if this has been asked before, is anybody suffering from the Bluetooth connection of Mate 10 pro?
gt_5454
I am using Spotify for my music and it doesn't have any EQ built in the app as well.
gt_5454
I do... Already reported to customer service. Do feedback too. What's ur symptom?
Bluetooth for me was very stable. I paired with my car stereo, Bluetooth headset and Xiaomi band all without drops and issues at all
